trainwreck with dumble style tonestack and switches
Tone Lover
Has anyone done a trainwreck with the dumble switching style for there tonestack. just thinking out loud I like the differant switches on the dumble clone i have and thought it would be a good addition to the trainwreck build I was going to do, but didnt know if there was something I was missing. Thanks Bill
Re: trainwreck with dumble style tonestack and switches
Not quite the configuration you had in mind, i don't think, but this combination really works well. I made this amp less the "clean" channel shown here. The boost switch gives that "little more" you want with a great clean sound or just about any kinda' drive you want.
a'doc1
a'doc1
Tone Lover
Thank you my friend that was a very interesting design some of the most interesting designs Ive seen latetly have been switchable EQ,s and master volumes.
Thanks Bill
Thanks Bill
Tone Lover
Ampdoc1 after looking this over these are two very differant tone stacks could you give an example what amp might use these and why you chose these two like is one better for a clean or so on. thanks Bill
The clean channel EQ values I show here are for a Roland JC. I'm not a jazz player or listener, but I played a JC for a wedding and really thought the clean sound was outstanding. I might not like it, but it'll be pretty easy to change values to taste.
Adding an additional switchable EQ is the only major thing I've added to a proven design I built a few years ago. In that amp the OD channel EQ (Trainwreck) shown here works really well in both the clean and OD modes, and the boost is a handy tool for both.
You may notice I have changed the plate and cathode values from the typical Express and Dumble designs. I picked by listening to different values at each stage and chose them to taste. Sounds pretty much like you'd imagine a TW/Dumble combo to sound. Clean/dirty, raw/smooth,..just dial 'er in.
I'm trying to find some PCB files I've designed for my build,..but I just worked my way out of a Window snag that has bollixed up my files for the past 3 weeks.
ampdoc1
ampdoc1
diagrammatiks
the rocket is set up a little bit differently but the it seems the express and the liverpool both have plate drive tone stacks after the v1a.
You could certainly copy over elements of the dumble ods clean stack without any increase in insertion loss.
However, the frequency response of the amp and the interaction of the controls will change.
If you look at this simplified schematic
https://tubeamparchive.com/files/ods50w ... ic_170.pdf
you'll see that there are differences in the pot values after the initial 100k/500pf input into the tone stack.
You could pretty easily add something that functions like the deep switch or the rock/jazz switch though.
You'll probably want to play around with the values though. The cathode bypass capacitors on the v1a's of the 2 amps result in very different frequency response curves at the tone stack input.
Tone Lover
Thanks guys good stuff. Man I hate it when my computer is messin up I saved a tone of files without backing them up and my computer went down ive never been able to find all the good stuff i had .
Thanks Bill
Thanks Bill
Bill can you be more specific on this? For switching what are you looking for and are you considering relays as well?Has anyone done a trainwreck with the dumble switching style for there tonestack. just thinking out loud I like the differant switches on the dumble clone i have and thought it would be a good addition to the trainwreck build I was going to do, but didnt know if there was something I was missing. Thanks Bill
Which Trainwreck? Are you talking about adding the overdrive section?
The Dumble has bright switch and deep switch but the next switch the jazz/Rock is tied to the OD section.
I build octal TW Rockets with bass boost switch, bright switch and gain boost switch but nothing Dumble about that.
Just wondering?
Tone Lover
You know Mark you just taught me something I didnt know that the jazz/ rock switch was tied to the overdrive section on the dumble.
I hadnt looked at it in a while I have several schematics and i had gotten confuzed on that one.
My original thought was the jazz rock switch /deep switch and mid boost. but I had gotten side tracked when Ampdoc1 threw that two tone stack thing at me, got me thinking in a little broader sense.
But any ideas that you think are cool are open for consideration you guys teach me something new every time a new idea is brought up.
Thanks Bill
PS. know I have to go look at my schematics again
just realized I missed something, for switching definitely relays
Thanks Bill
diagrammatiks
Mark can you explain the jazz/rock switch in relation to the od?M Fowler wrote:Bill can you be more specific on this? For switching what are you looking for and are you considering relays as well?Has anyone done a trainwreck with the dumble switching style for there tonestack. just thinking out loud I like the differant switches on the dumble clone i have and thought it would be a good addition to the trainwreck build I was going to do, but didnt know if there was something I was missing. Thanks Bill
Just wondering?![]()
Tone Lover
Guys I forgot the one dumble type amp I had made was a highbred here is the jazz rock switch I was talking about. I really liked what it did for the amp.
Thanks Bill
Thanks Bill
