Tiny Terror Hard Wired repair / resistor
rp
Re: Tiny Terror Hard Wired repair / resistor
Post by rp »
Cathode Resistor, sets the output tube bias.
Cliff Schecht
Post by Cliff Schecht »
I thought the tiny terror was a SE amp..
Cliff Schecht - Circuit P.I.
Cliff Schecht wrote:I thought the tiny terror was a SE amp..
Nope. PP with a pair of EL84.
guitarmike2107
Post by guitarmike2107 »
If this was the cathode resistor it's too big, and will be biasing your tubes cold. Cold cathode bais amps suck... IMHO
However I am confident it is not the cathode resistor, but you would be better asking what the fault was.. I think you have a right to know.
My bet is still on the screen supply.
Cliff Schecht
Yeah I'm thinking screen now too. I thought the tt was a SE which is why I said cathode.
mjbmjb
Post by mjbmjb »
the regular chinese production Tiny Terror is a circuit board amp. The Tiny Terror Hard Wired version is a point to point hand wired amp made in the UK.
What does SE amp mean....?
Yes, I'm going to get the dealer to follow up and get a description of what exactly was done.
Single Ended
mjbmjb
Post by mjbmjb »
So does point to point mean it is not SE and that it can't be a cathode bias resistor?
Masco
Post by Masco »
It's a big ass bloody screen resistor! So you've got a 2-3W metal oxide on one side and this monster on the other.
Single ended means an amp that has only one power tube (pentode or triode). Push-pull amps have pairs of power tubes.
SE and PP amps can both be point-to-point wired.
Masco
Post by Masco »
Actually, SE amps can have multiple power tubes as well. I think of it more as no primary CT for the OT.
mjbmjb
Post by mjbmjb »
Ok. Thanks. I'll stop annoying you guys. :lol: I think I should stick to a non builder forum. It was good to hear your thought though as you guys seem to know what you are talking about more than your average amp guy - me -....
It sounds like tone isn't compromised and this is a good repair. i'll sleep easier.
Thanks again
Mike
rp
Post by rp »
Thanks for the pics, now we can clone it :lol:
