David Root wrote:You are without doubt the Michaelangelo of the amp chassis! Those pix should be in a textbook! They would have been 60 years ago!
I agree with Dogears, step out a bit with some nice NOS! I know it's not historically correct but I would love to know how some Heerlen Amperex 12AX7s or RCA blackplate 12AX7s sound in that amp. #183 with a buffered loop is on my list, I have a four tube 1/8" chassis in stock and a nice blonde head w/brown Vox grille just yearning for a nice amp!.
Ha Ha! You’re being very nice David, I’m humbled. Heck, I would’ve been stoked if you said Jackson Pollock!
Cool, that you got the 4 tube chassis. I should have, but I was on the fence if I could implement the loop correctly.
BTW, Is there a good reference or book around for researching NOS tubes?
triodecr wrote:Damn that's a clean build!!!
Makes my 183 look hideous.
Nice job!
Thanks! Hey, as long as it’s reliable and sounds good right?
CHIP wrote:Very nice build.
I have the same PT as yours, but my unloaded voltage came in about 25 volts lower.
I never did understand why, I had to put a 1k power resistor in place of the 3k 10watt in order to get my preamp voltages right.
Thanks Chip! Yeah, saw your thread and I wondered about that too. I was not thrilled about the prospect of going in there and yanking the 3K out after everything was installed but to my surprise the B+ was higher than yours. The only things that are different with how you wired your PT is that you used the heater CT instead of the 150R virtual ground resistors and that the relay power secondaries are taped-off in favor of an auxiliary relay PT. These two things surely can't be of concern though. The only other thing I could think of is your line voltage, brand of tubes and your bias setting. I’m still wondering about that though.
talbany wrote:Jonas
  Ya done GOOD!! my brother..
Are those Q-Lines? and where on earth did you score those.. I want clips..ASAP..+1 on NOS
Thanks Tony! And thank you for a STELLAR 183 layout. Your layouts are so good that at this point the D-man himself is probably cobbling something together from one of em’. Oh no! Blasphemy!!!
Yep, I sprinkled some Q-line goodness in select spots. Ebay ma friend! I simply searched for “Sprague resistors”, they pop up every once in a while. Let’s have a good bidding war next time some show up!
