miniHRM evolution
azatplayer
Re: miniHRM evolution
Post by azatplayer »
Ahhh, i think im being a bit tightass ;) I hve a 16 inch chassis to work with, just figuring that its a small 5 watter and wanting a really easy to dial in grab and go, rather than a tweaker. I mean I LIKE tweaking but for a small club gigger, you wanna just get it quickly into place.
But you are right, build it at spec, then dial in what is needed against whats not.
After all, dont wanna be called a one trick pony do we!
Work has been off the chart this last couple weeks, have not got the punches out yet!!!! Im still workin the layout tho, think im goin tagstrips, so trying to keep it as clean as possible. Tagstrips look great till the wire gos in...;)
Wanna get it clean and mean!
rogb
Post by rogb »
azatplayer wrote:Ahhh, i think im being a bit tightass ;) I hve a 16 inch chassis to work with, just figuring that its a small 5 watter and wanting a really easy to dial in grab and go, rather than a tweaker. I mean I LIKE tweaking but for a small club gigger, you wanna just get it quickly into place.
Yeah I have revised my rear panel and sent it off, hope I can catch it before they cut it. Added the OD Master and an HRM lift switch.
Still only 4 pots and 4 switches on the front.
Going to get the rest of the cab parts today and finish that off.
Also build the PS and HRM boards.
https://tubeamparchive.com/viewtopic.ph ... 240#159240
Yeah this is a grab and go but I need to tweak for some different sounding guitars. Gonna build a butterscotch Tele with Callaham iron
:D
azatplayer
Ahhh tele man, good work!
azatplayer
Mat have you given thought to what operating point you are gonna run the PP 86 at?
I built a killer 15 watter recently, maybe the best little amp ive heard actually. Running 335V plates on that one. I understand the theory behing lowerr plates in single end, but just curious of you are thinking lower plates or higher, as im not sure how dumbles generally run the powwer section.
Cheers mate.
mat
Post by mat »
azatplayer wrote:Mat have you given thought to what operating point you are gonna run the PP 86 at?
Cheers mate.
Hi azatplayer,
I will use PT that has 3 secondary windings. I don't have earlier experience of that trafo but will report when it will be ready.
I got free afternoon today and drove to band rehearsals pit and recorded real quick (but long) demo of the 86 Special Jr running in to nonHRM (50W) power amp. The second demo is the Jr by itself.
The feel with nonHRM PWRamp is naturally much stiffer. The 86S is much joyable to play. The power amp seems to play a big role on the playing feel.
http://soundclick.com/share.cfm?id=10455911
http://soundclick.com/share.cfm?id=10475602
Edited the second clip ending. Just a little different fadeout.
mat
rogb
Post by rogb »
Holy moly Mat, the second clip is smokin' GOOD :D
:D
Is this a taste of what I've got in store when I get this 86 finished? :shock:
Just finishing up the cab today, did an oval port for the back, and should pick up the faceplates in a day or two. Put the OD master on the back panel.
I'll do a cab shot when it's finished.
Cut out the boards today too.
mat
Post by mat »
azatplayer wrote:Thanks Mat.
hey the pics of your amp show only 5 pots but the schemo has 7.
I know the pre volume is a trimmer, what is the other one that you have as a trimmer? The OD level?
Im keen to keep the front simple as possible, as i like on any build.
Thanks buddy.
My 86-Special (left to right): Clean master, OD master, clean/OD sw, OD, OD tone, bass, bright sw, treble, boost sw. Mid boost on back panel.
mat
dreric
Post by dreric »
Mat (and all those contributing to this thread),
I wanted to complement you guys on taking the HRM into a new realm. The clips sound great and I'm interested in building one.
What missing for me is visual reference. Any chance of seeing some pictures, esp "gut shots"
Thanks again for your contributions.
Eric
mat
Post by mat »
rogb wrote:Holy moly Mat, the second clip is smokin' GOOD :D
:D
Thanks :D
You should have same sounding amp as mine. I encourage to experiment with speakers to get optimal sound for You.
I'm not yet tried the amp with dlator style circuit. I've built the first kleinulator (dumbleator with jfets) years ago and I will test it with the 86-Special..... when I find the time.....
Good luck with Your build ! Take some pics of the process and post here.
I got the chassis made by my work mates wife :D She is very skillfull metal worker. Will post pics of the working process too.
mat
mat
Post by mat »
dreric wrote:Mat (and all those contributing to this thread),
Eric
Hi Eric,
My amp is at the rehearsals place (please give me a better word for that :oops: ) now. The amp has evolved many versions and is nothing pretty to look but I will take pics if someone wants to see the insides. We play next time at sunday. I try to remember to take few photos then.
mat
da Geezer
Post by da Geezer »
Cheers mate.
Hi azatplayer,
http://soundclick.com/share.cfm?id=10455845
WOW!...THAT is excellent tone!
G
mat
Post by mat »
Cheers mate.
Hi azatplayer,
G
Thanks :D
mat
10thTx
Post by 10thTx »
Just unbelieveably COOL!
Fantastic tone! I just loved that & as always your playing is just remarkable.
With respect, 10thtx
mat
Post by mat »
10thTx wrote:Just unbelieveably COOL!
Jeff, thanks for Your kind words.
After listening the song couple times I can but wonder how I keep sending these raw clips again and again. Well, no one to blame but me. Too many and too high notes all the place. Next clip with more economical playing :roll:
mat
dreric
Post by dreric »
Eric
Hi Eric,
Thant would be great, I'm sure that I'm not the only one who wants to see inside.!!
