OT: powering a 9vdc pedal with dc adapter
Sorry for the off-topic post. Irksome, but hopefully simple problem. I built this booster pedal kit: http://generalguitargadgets.com/pdf/ggg ... a841b3e85a
Works great when powered by 9v battery. But I want to power with "wall wart." I have tried several, and when connected, they cause a loud buzzing, with the guitar's signal barely audible. I eliminated variables by measuring the DC voltage and polarity, and using a model with a 9v plug adapter, so it looks exactly like a battery to the pedal. No help.
Why am I getting such nasty buzzing? Is this booster SO sensitive to a little rf noise or ripple or whatever that I can only use a battery? Or maybe I can throw an appropriate cap in there?
ToneMerc
Re: OT: powering a 9vdc pedal with dc adapter
Post by ToneMerc »
I find that most of the "wall warts" have a fair amount of AC component riding on the DC. Also, the input filtering of many of these pedal projects tends to be conservative outside of using a battery as the source. It could be either of these or even a lead dress/layout issue.
TM
Did you add a DC power jack to your pedal or using a snap 9v lead?
Did you reverse the polarity?
I haven't had any problems with the booster pedal I built from their kit using Godlyke power-all.
M Fowler wrote:Did you add a DC power jack to your pedal or using a snap 9v lead?
A DC jack AND 9v snap lead were both included in the layout. According to continuity testing, the DC jack's normally closed switch is working properly when I insert the DC adapter plug. Never mind, though--I'm using a DC adapter exactly like a 9vdc battery, connecting it to the pedal's 9v battery clip, and getting that nasty buzz.
I have a One Spot power adapter on order; I'll try that when it arrives.
Here is a photogram.
I'm wondering if you are then have switched the voltage + / - using the snap on 9v adapter?
I was careful about that. And I tried it both ways!
Super_Reverb
Post by Super_Reverb »
I suggest measuring the AC voltage at the output of the 9V DC wall wart. It should only be a few mV. Most of the modern adapters are based on more compact switching regulator designs; switchers operate at 10s or 100s of kHz.
You may need to find a quieter p/s or use some filter caps and a series choke to tame it. If this is the case, required inductance to filter at switching frequency will be much lower than typical 120Hz filter requirements.
cheers,
rob
Super_Reverb wrote:I suggest measuring the AC voltage at the output of the 9V DC wall wart. It should only be a few mV. Most of the modern adapters are based on more compact switching regulator designs; switchers operate at 10s or 100s of kHz.
Reads about 30mV AC. Can you suggest how to filter with caps?
tubeswell
Post by tubeswell »
xtian wrote:. Can you suggest how to filter with caps?
Same as a Pii filter supply in a tube amp (but you don't need such hi-voltage caps). If you have a +ve ground, then e-caps go in with the "+" side to ground.
jjman
Post by jjman »
xtian wrote: Reads about 30mV AC. Can you suggest how to filter with caps?
Just get a One-Spot or other regulated unit. Will show 0vac.
Masco
Post by Masco »
Or add a 9v regulator.
vibratoking
Post by vibratoking »
This could be several things. Polarity is one possibility, but you said you verified that it is correct. An external power supply can introduce hum via a ground loop. Have you verified there is not a ground loop? A simple three prong to two prong adapter should fix it if one exists.
I think it's a polarity issue but you verified it isn't so I am at a loss here.
This pedal requires DC power supply or AC power supply?
Polarity is not the issue, nor is ground loop.
I have a One Spot arriving this evening, and I'll let you know if that solves the problem!
