Two rock custom reverb sig sounds and guts
paisley_tele
Re: Two rock custom reverb sig sounds and guts
Hook the blue wire to where every u want
paisley_tele
Tee he he
paisley_tele
Dunno what to say but to all a good night after I. Delete the rest
paisley_tele
Wow there was alot I document of this
paisley_tele
Those were the swithes
paisley_tele
All that time I wasted to help losers
paisley_tele
Agh the voltage pic 900 at the tubes remember that
paisley_tele
WOW!
Thank you for all the work that you are sharing with the group!
Eric
Eric
paisley_tele
oops theres a choke in there. thank you guys. just tring to pull my weight.anyone got some spare parts for me?
So what's the deal with the markings on the 6PS caps? I'm guessing it's something to do with "Polarity" and I have read somewhere that even though poly caps are bi-polar, they do sound better when orientated one way more than the other.
Is there any factual evidence for this and if so how do you determine which way round is best (other than trial and error)?
exocet wrote: .............. how do you determine which way round is best (other than trial and error)?
http://www.youtube.com/watch?v=VP6ZIHXq6Yg
Easiest way is to clip lead the cap to an amplifier input (turned up) and squeeze it with you fingers - switch the lead to the opposite ends and squeeze again - noisiest way means outer foil is connected to your positive clip lead. Put a stripe on that end.exocet wrote:So what's the deal with the markings on the 6PS caps? I'm guessing it's something to do with "Polarity" and I have read somewhere that even though poly caps are bi-polar, they do sound better when orientated one way more than the other.
www.RedPlateAmps.com
Brilliant, Henry!
Gil
Gil
heisthl wrote:Easiest way is to clip lead the cap to an amplifier input (turned up) and squeeze it with you fingers - switch the lead to the opposite ends and squeeze again - noisiest way means outer foil is connected to your positive clip lead. Put a stripe on that end.exocet wrote:So what's the deal with the markings on the 6PS caps? I'm guessing it's something to do with "Polarity" and I have read somewhere that even though poly caps are bi-polar, they do sound better when orientated one way more than the other.
