Rocket Documents
Trainwreck schematics, designs, pictures. Only members may post files here.
dave_b
Re: Rocket Documents
Post by dave_b »
Ron Worley wrote:Obviously, it's electrically immaterial, but I will check it out and correct if it's backward..... it very likely that you are right!!
Ultimately, my best contributions tend to be immaterial. :D
Ron Worley
Post by Ron Worley »
Nah, I'm just anal enough to make the change!!!
Ron
fayser
Perhas a dumb question.??
Post by fayser »
Guys... new to the forum here but I was wondering if it possible to just remove two of the El84s from the circuit... would to do this require one to change all the rest of the circuit due to voltage shifts etc?
Thought this might give one a lower wattage amp?
eddie25
Post by eddie25 »
Seems like the labeling of V5 and V6 should be switched around in the schematic. As it is, one side of the OT primary goes to V4 and V6, and the other side goes to V5 and V7.
Ron Worley
It can be (and has been) done either way: V4&5, and V6&7 together or 4&6, 5&7 respectively
Ron
amplifiednation
C4 Cap
Post by amplifiednation »
the optional C4 cap, which i believe to be a cathode bypass cap for V2, is said to "increase gain"??? would it just go in parallel with R7?
Amplified Nation
www.amplifiednation.com
@ampnation
ampgeek
Post by ampgeek »
Precisely! It is a cathode bypass cap and would go in parallel with R7. It allows AC coming through the tube to pass to ground. Thus, not allowing it to mess with with bias of the tube (e.g., cutting off too soon).
Do note that polarity is important if using electrolytics in this spot. + end goes toward the tube. - end to ground.
Cathode bypass caps also represent an excellent tone shaping tool. Higher values produce a more low end rich tone. Lower values the opposite.
Dave O.
Put that cap on a switch because you're not going to always want that much gain if you know what I mean.
I usually add a 10uf and 22-25uf on a switch: down 10uf, center off, and up 25uf boost.
Actually even as low as 2uf can really add some nice gain. Make that a 3 way switch for some nice flexibility.
Add another switch for the V1a bypass cap for .68 low and standard 25uf for high tone switching.
angelodp
footswitch
Post by angelodp »
Or do a foot-switch.
A
Or do a foot switch, yes that is a nice option Ange. :)
angelodp
floor
Post by angelodp »
Yah, boost on the floor.... yeha!
amplifiednation
M Fowler wrote:Put that cap on a switch because you're not going to always want that much gain if you know what I mean.
I love it. I am going to mini toggle the hell out of my rocket
Amplified Nation
@ampnation
amplifiednation
Mark I dont fully understand the high tone switching. Brite switch?
Amplified Nation
@ampnation
hunoz
Corrections not reflected in down-loadable files
Post by hunoz »
Hi Guys,
I am new to the forum. Just wondering why it is that the down-loadable files do not reflect the corrections for the errors you already identified?
Andy
Zippy
Re: Perhas a dumb question.??
Post by Zippy »
fayser wrote:Guys... new to the forum here but I was wondering if it possible to just remove two of the El84s from the circuit... would to do this require one to change all the rest of the circuit due to voltage shifts etc?
Most just call that a half-power mod - some do it by separating the cathode bias resistors and lifting the ground connection on one pair. True, it will make a subtle difference in voltages - up to you if it matters.
You could make a half power (18 watter) or 30 watter with a switch - if the former, you won't have the "correct" trannie set (since Ken never did it that way).
