Inside I measure 295V plate voltage on the power tube, and 10V cathode voltage. The 200Ohm resistor I installed in my restoration project will draw about 0.67mA (I'm not sure if we are talking mA or A here excuse me and please correct me if I am mistaken
(Wov... I did not think 6 months ago that I would ever be capable of saying that..)
Anyway back to the problem...
I tried substituting the preamp tubes, no effect. Investigating inside I found no broken solder joinst, weird voltages, broken components or wires. There is continuity between all points in the circuit.
Removing the effect tube removed all sound. The same happened when removing the preamp tube.
I'm guessing that the first gain stage of the preamp circuit has cut out somehow, and all we are hearing is the final gain stage and the effect gain (What was that called again buffer?) But then again my experience with circuitry is isolated to this amp and a couple of stomp boxes I've built so this could probably be anything.
Any ideas folks?
All thoughts greatly appreciated.
Schematic for the amp can be found in my restoration thread here:
https://tubeamparchive.com/viewtopic.ph ... highlight=
Cheers!
DocZ
