Have a set of transformers trying to figure out the PT current rating,
A0-24596-1
9496249
Are the codes on top of the bell.
For Reference, the OT
A0-24158-0
9496247
Tube compliment was a pair of ECL86's, and a EZ-81
						AO-44 PT Specs
Re: AO-44 PT Specs
There's a lot of guys selling (the same) replacement trannies, but no specs.
Just a guess, with those tubes you probably have 6.3VAC @ 3A and 100-150mA on the HT. But you probably knew that...
Re: AO-44 PT Specs
Hi John- I can't offer an exact answer, but I do use these amps as a donor amp to build 18 watt Lite circuit amps from.  Both with a tube rectifier and a diode rectifier.  That powers two el84 power tubes and 2 12ax7 preamps and a rectifier tube.  Never any problem with that load.  I find these to be pretty robust but smaller than the AO39 amps or the AO35 (Dr Z liked these for his Carmen Ghia series when he started).
Hope this helps
						Hope this helps
				Philoffline
Re: AO-44 PT Specs
mmmoser -- sorry to hijack the thread, but do you squeeze some sort of eyelet or turret board into the ao-44 chassis, or do it all PTP?
I recently did something similar with an ao-43, and I'm thinking about a smaller footprint for the next one.
Any old tagline will do
						Re: AO-44 PT Specs
PT 250-0-250
The PT is fairly robust considering it runs a EZ81 rectifier, and 2 ECL86 tubes without even sweating.
I have one built up by mmmoser as a Lite IIb and it rips.
						Re: AO-44 PT Specs
Hi- yes, that is one of my little amps built into this chassis.  I do build a very compact eyelet board for these little guys.  As you can see, its really a combination of some point to point and eyelet board.
									Frugal Amps
				Philoffline
