I have a scratch built bass amp based on the ampeg B15N circuit with some modifications - the major ones are: I only have one input channel, and I'm using a 5U4GB power tube instead of the 5AR4. My chassis was scavenged from a wurlitzer organ amp, and I'm using it's PT which was meant for a 5U4GB and 6L6GC power tubes. During the build I worked through the numbers from the datasheets for the different power tubes and concluded that the 5U4GB should work fine in my circuit, and I think it has been - I've been using the amp for several weeks now.
The other day, I was playing through the amp, facing so that the amp was in my peripheral vision. All of a sudden there was a bright flash from the amp's direction, accompanied by a very small 'tick' from the speaker. I jumped over to the amp and shut it off, and proceeded to talk myself out of hyperventilating
 .  I'm 90% sure, in hindsight, that the flash came from the power tube.
.  I'm 90% sure, in hindsight, that the flash came from the power tube.Today I got up the nerve to put it on the bench and check things out. All the voltages seem to be fine, nothing seems to be smoked or getting too warm, and it's quiet. I plugged in the bass and played a little bit, and it seems normal...
So my question is: What the hell happened??
Thanks for any insights!
