which clean channel do you prefer?
* HRM
* Non-HRM
* Fender
Thanks for your help in advance!
 Regards,
Markus
 Sounds great!Bob-I wrote:What I did is built an amp with 3 channels. Since your plan has all the appropriate components you could do that too. My first channel uses Fender values, the second is an HRM and of course the 3rd is the OD. I use 2 relays for channel switching, the first switches between Fender and Dumble, the second switches between Dumble clean and OD.
  ) I fear that it would be too large because I intend to put the circuit into a stompbox. OK, it will be a huge stompbox
 ) I fear that it would be too large because I intend to put the circuit into a stompbox. OK, it will be a huge stompbox   but still I think that it would be too large. Also the xfmr I'm planning to use (and order easily) http://www.musikding.de/product_info.ph ... cts_id=944 will power just 4 tubes. This xfmr is the smallest solution I could find and since there isn't too much space in the box I'd like to stick with it.
 5 12AX7's... no only 3. One for the Fender channel and 2 for the Dumble clean and OD channel. I like the HRM OD channel myself, but I have an Hybrid that sounds great too.markusw wrote:Sounds great!
If I did the calculation correct this would be 5 12AXs.
So if you had to choose ONE clean channel and ONE complete (4 stages) OD channel, which of them would you take?
Regards,
Markus
First I thought you build a 3 channel with both a complete HRM and a complete non-HRM. That's why I came up with 5 tubes. But actually that would then have been 5 channels....5 12AX7's... no only 3.
 Anyway, I think I got you now
You mean a HRM to Hybrid switch?? How many relays would that need? Suppose somebody already checkedOne of these days I'll have to get creative and build in some switching options.
 )..One more option to consider for my buildLuthierwnc wrote:FWIW, I like the HRM clean channel with a Dumbleator running at just over parity. Much more than that is too much for the OD. Skip
