I wonder when HAD build his last ODS combo amp,
can we say that all ODS combos were 50w,
while all heads were 100w?
						last combo
last combo
						Re: last combo
Hi two tone,two tone wrote:I wonder when HAD build his last ODS combo amp,
AFAIK he didn't build his last ODS combo yet as he's still building amps.
You will find 100W combos at least since the introduction of the 2nd generation amps with the new larger chassis size and all the filter caps in the chassis and the FET circuit no longer on the preamp board but on the small FET board.
Here are two links to pictures of 6th generation style 100W combo amps:
http://personalpages.manchester.ac.uk/s ... known%203/
http://personalpages.manchester.ac.uk/s ... known%204/
Max
				BlackIrish
Re: last combo
Hi MAX, just curious from the stories posted and artists supposed to be refused, big names I read. Whom may I ask is he building for? And I must ask if you know a price range for an ODS.
I have searched for a thread with these answers but have not found any. Maybe you know of a link?
Thanks for any info
Thanks for any info
turn it all up
						Re: last combo
Hi BlackIrish,BlackIrish wrote:Maybe you know of a link?
Look here for a start:
https://tubeamparchive.com/viewtopic.ph ... 389#146389
https://tubeamparchive.com/viewtopic.ph ... 631#145631
Max
				BlackIrish
