The odd shaped IEC only needs a rectangle opening.
No need to cut the angles at all.
The IEC plug covers the rectangle opening completely.
I Needs A Nibbler!
Re: I Needs A Nibbler!
I was lucky enough to find an NOS Greenlee rectangular punch on Ebay. It was almost the right size, and I had to file a little to open it up. Unfortunatey, it got dull, and I hope to get it sharpened. it doesn't use a ball bearing, so it took a lot of work to get it through. Nonetheless, there was no mess or guess, and the hole looked really pro.
Now my big problem has been making a matching a rectangular hole in an 1/8" plexiglass faceplate! I've done a few, but man is that difficult. good thing plexiglass is cheap!
I have a Snap On air nibbler, that I've worn out a couple of punches, and dies on. I used to have to install a lot of accessories in the vehicles back when I worked for the power company. I also used it to help build the panels used in the substations. Once you've spent a little time with one, you can really do very close cuts, using only your layout lines.
As for clean up, (with ferrus metals), a few magnets on the back side of the work, can catch most of the half moons.
Gaz when I have made holes is Lexan or Plexiglas I drilled holes in the corners of the opening I am making.Gaz wrote:I was lucky enough to find an NOS Greenlee rectangular punch on Ebay. It was almost the right size, and I had to file a little to open it up. Unfortunatey, it got dull, and I hope to get it sharpened. it doesn't use a ball bearing, so it took a lot of work to get it through. Nonetheless, there was no mess or guess, and the hole looked really pro.
This helps prevent the material from cracking as you work it.
I usually err on the cautious side but have used my Dremel tool with a fine grit cut off wheel for this before.
Or a fine toothed jig saw blade and cut holding it in my hand or vice grips.
Depending on how long the cuts are.
Anyway, I can think of other things more fun.
