Time to bite the bullet...
Re: Time to bite the bullet...
Thanks Paul, that is good information about the frequency and the need for two channels.
I got my used Tek 60mHz scope at a amateur radio "hamfest" for a reasonable price.
There's usually a test equipment vendor at these events that you can buy from in person.
rd
rd
I found a Fluke model 97 for $250 in a pawnshop. Its 2ch 50meg, 1998, has numerous features. plus built in meter with rms measurements, frequency , others. It also has a sinewave osc. and does dbm and power measurements in watts with a defined impedance 4,8 16 up to 10k. It had 1 set of probes and will measure easily in the 1.8k volt range with the 10 to 1 probe with an auto cal . Make sure if you find one to get the powersupply wall wart and probes or you could spend quite a lot getting them after the purchase. Its great and portable as well.
I still have my old hitachi dual 20meg that works but needs gone through from time to time. It's been dirty switches or a bad electrolitic caps. You can calibrate yourself because it has a built in reference for voltage level and timebase cals.
- David Root
I have a Protek 3502-C, I think it was $398. Two channel 20MHz. Chinese of course.
- daydreamer
"Too young to know, too old to listen..."
Suze Demachi- Baby Animals
I found a Tektronix 475 for $125 on Craigslist. 2 channel 200 MHz. If you keep looking around you can find some really good deals out there.
Got a Tektronix 465 100 MHz off ebay (less than $100). Was a bit of a search.
Only went that route because the guy was local and actively using it (for CB Radio repair).
The tek 465 is a nice one. I use one too and I love it.
