I've got a 50 watt New Sensor OT for a Marshall JMP/JCM and no diagram for the secondaries. I think it is called the MOT-50 or something similar. Does anybody know where I can find this diagram, or of a website where these trannies are available? The 2ndaries are yellow, purple and orange.
Thanks much,
Dave
New Sensor OTs
Re: New Sensor OTs
Are you sure that's an MOP-50 from New Sensor? The ones I have used had 4 wires out of the secondary for 4, 8, and 16 ohm plus common. attached is a gif file on the MOP-50
Great things happen in a vacuum
- titanicslim
Re: New Sensor OTs
Yes, yellow, purple, orange and black, but I thought it was called an MOT 50.bnwitt wrote:Are you sure that's an MOP-50 from New Sensor? The ones I have used had 4 wires out of the secondary for 4, 8, and 16 ohm plus common. attached is a gif file on the MOP-50
Have you got the url for the site where you got that gif?
Dave
The denunciation of the young is a necessary part of the hygiene of older people, and greatly assists in the circulation of the blood. - Logan Pearsall Smith (1865 - 1946)
- Funkalicousgroove
Re: New Sensor OTs
Put the leads on your DMM, the one that measures the most resistance to the common is the larger output.
Re: New Sensor OTs
Nope,
I think my sales contact at New Sensor sent me those years ago.
Here is their listing for Marshall replacement trannies:
Replacement Transformers for Marshall®/Vox
Replacement power and output transformers built to vintage specs with correct interleave ratios and lots of iron. Perfect upgrade for later and re-issue Marshalls®. Great replacements for many other vintage British amps. High quality - Classic sound.
Output Transformers for Marshall®
MOP-50
(Code# 17D010) 50 Watt
MOP-100
(Code# 17D020) 100 Watt
MOP50-T
(Code# 17E050) MOP 50 WATT TRANSFORMER (Made in Taiwan)
Power Transformers for Marshall® 1 6 buy it
MPT-50
(Code# 17D030) 50 Watt
MPT-100
(Code# 17D040) 100 Watt
MOP-50
MOP-100
MOP50-T
MPT-50
MPT-100
- titanicslim
Re: New Sensor OTs
Thanks, Funk! That's it. I had measured before and got erratic, unrepeatable readings on all three. Then I noticed the "low battery" symbolFunkalicousgroove wrote:Put the leads on your DMM, the one that measures the most resistance to the common is the larger output.
