Board, PS, Relay boards ready. Picture works now!
Tdale
Post by Tdale »
I'm starting to assemble as soon as I get the chassis ready...
Here is picture
Tommy
Tdale
Re: Board, PS, Relay boards ready. Picture works now!
Post by Tdale »
Hmm. There was something wrong with the picture..but it should work now.
Tommy
guittguy1
Post by guittguy1 »
That really makes Me want to build one! Got too many other projects waiting to be finished though.
BobW
Post by BobW »
Tommy, that's a great looking start, did you make your own boards and panel labels?
BobW
Post by BobW »
HiGain
Post by HiGain »
Nice!
Jake
MarkB
Post by MarkB »
The wiring of the 100uF filter caps has me puzzled. Are they parallel wired? It looks like there's a resistor between the two ground leads - I must not be seeing something.
Normster
Post by Normster »
MarkB wrote:The wiring of the 100uF filter caps has me puzzled. Are they parallel wired? It looks like there's a resistor between the two ground leads - I must not be seeing something.
What you're not seeing is a wire that runs diagonally from positive of the right cap to negative of the left cap (under the board).
MarkB
Post by MarkB »
I figured that had to be it. :D
Tdale
Post by Tdale »
Yes, there is a diagonal wire under it.
I made the boards myself, and the panel labels too. The chassis is about to be finished, and I can't wait!!!
Tommy
