2xel84 rocket
paisley_tele
2xel84 rocket
Post by paisley_tele »
any one have the layout for a 2 x el84 rocket ?
Re: 2xel84 rocket
Just drop off the two extra tubes and run the OT at 7k or 8k primary.
Uses the same PT or you can use a 290-0-290 as well with 8k OT.
Colossal
Re: 2xel84 rocket
Post by Colossal »
And change your cathode bias resistor to reflect two tubes instead of four
Re: 2xel84 rocket
I knew I was forgetting something important Dave.
120R to 150R should do.
statorvane
Re: 2xel84 rocket
Post by statorvane »
I've been thinking about a two banger Rocket too for my son, but with 6V6s. Would the power tube shared cathode resistor need to go to, say 300 ohms? I think the OT could still be 8K. Is that right?
Thanks.
loctal
Re: 2xel84 rocket
Post by loctal »
My two hole rocket "Bella" uses a 250-0-250 V at 150mA power transformer, a 10K sansui output transformer, and a 100 ohm cathode resistor on the EL-84's.
FYL
Re: 2xel84 rocket
Post by FYL »
I've been thinking about a two banger Rocket too for my son, but with 6V6s. Would the power tube shared cathode resistor need to go to, say 300 ohms.
Depends on your B+. With 320V or less, 250R is perfect; 270R to 330R should be used with higher B+.
Yup.
mcrracer
Re: 2xel84 rocket
Post by mcrracer »
The 4 hole Rocket uses a 5.2k OT. Shouldn't a 2 banger use a 10k?
Re: 2xel84 rocket
Depends do you want a 8k Marshall tone or the 6k Fender tone or down more to the Spitfire 4k tone.
I have seen many different values used for EL84 or 6V6. :?:
mcrracer
Re: 2xel84 rocket
Post by mcrracer »
Doesn't the 4 tube Rocket use a 5.2k OT? I am talking about how Ken voiced the Rocket. I just wanted to know if lowering the impedance on a 2 tube EL84 Rocket would change the tone and response?
funkmeblue
Re: 2xel84 rocket
Post by funkmeblue »
why not use the a470's little brother.....http://store.triodestore.com/z517wadyoutr.html
mcrracer
Re: 2xel84 rocket
Post by mcrracer »
I don't shop at Triode and in my opinion that transformer is over priced for the build in question. I am a more budget minded builder.
Re: 2xel84 rocket
Here is some info on the Marshall 18w transformer
NOTE: ORIGINALLY DESIGNED FOR 3/7/15 OHM LOADS
PRIMARY IMPEDANCE = 8.5K OHMS WITH 3 OHM LOAD
PRIMARY IMPEDANCE = 8.2K OHMS WITH 7 OHM LOAD
PRIMARY IMPEDANCE = 8.0K OHMS WITH 15 OHM LOAD
WITH 4/8/16 OHM LOADS, PRIMARY IMPEDANCE =
PRIMARY IMPEDANCE = 10.8K OHMS WITH 4 OHM LOAD
PRIMARY IMPEDANCE = 9.2K OHMS WITH 8 OHM LOAD
PRIMARY IMPEDANCE = 8.4K OHMS WITH 16 OHM LOAD
loctal
Re: 2xel84 rocket
Post by loctal »
The dynaco A470 transformer used in the rocket is a hi-fi transformer. I thought about using the little brother transformer but I couldn't find a real one on fleabay. Sansui transformers are high quality and I found one for $20.00 in Peru. It cost $45.00 to ship it to America. When I build a real Rocket clone, I will buy a vintage A470. These rocket amps sound freaking great! If anyone has built one with a Radio-spares type transformer, please share your results with the forum.
dartanion
Re: 2xel84 rocket
Post by dartanion »
The Rocket (A470) OT is ~4.3K primary IIRC.
Also, using the PT from a 30W Rocket will cause your voltages to be high across the board as it's not sufficiently loaded. These PTs are over-sized to begin with, so you'd be best served to use a smaller PT.
I have custom transformer sets that would fit the needs of a two hole Rocket if anyone is interested. The PT is a 150mA version of the 5199, and the OT is 8.6K Woden style. For those interested in a set, shoot me a PM.
