Very nice schematic! I can see that the boost switch will break the contact between the bass-pot wiper and the treble pot in one position.HiGain wrote:The switch breaks the cold lug (1) of the treble pot and the wiper of the bass pot. The signal then travels mainly through the treble cap and lugs 3 and 2 of the treble pot. It also leaks a little through the slope resistor and bass pot (the maximum value of the pot).
Please point out errors in the drawing.
-Jake
I can also see that when the boost switch is in the other position, there will be contact between the bass-pot wiper and the treble pot BUT, it seems that the rock/jazz switch has to be in a certain position for that to happen.
With the rock/jazz switch in a positon where the commons are in contact with the two upper lugs, there will be contact between the bass and treble pot.
But in the other position, the signal from the bass pot will go through the 100K resistor, directely to the volume pot
Also, when both switches are in the position shown, the upper bass-pot lug and the bass-pot wiper are connected through the switches....is that correct?
Tommy
