Amp Cradles: make one or buy one?
guitarmike2107
Re: Amp Cradles: make one or buy one?
Post by guitarmike2107 »
Structo wrote:Yes, that is a good way to build the cradle.
I have those same plans.
Make sure to have the arms so the amp chassis is back a ways from the center line of the cradle.
When I first built mine the whole works wanted to flip over because of the uneven weight distribution due to the transformers.
So I made two more arms, longer and further back on the end with the stops.
Also make sure it is tall enough so you can put a chassis with tubes in it that hang down and don't hit anything. :wink:
Hey Struco, Did you build yours exactly to those plans, or are you just giving further advise. If you did I can get the plans changed to make them wider taller etc
Mike
No I had built my cradle before I found those plans.
I think it was Ron Worley's cradle I tried to copy.
I used the lazy susan things on the arms but found the chassis wanted to spin so I drilled holes in the arms that I stick screws in to lock it so the chassis is either at a 45 degree angle or flat.
[IMG:800:600]http://i23.photobucket.com/albums/b392/ ... G_0183.jpg[/img]
guitarmike2107
thanks Tom
I put those plans together, but have never had the chance to build one myself :oops: so was just curious
cheers
Mike
Yeah, if you stick with those plans I think it should turn out good.
I wish I had them available when I built mine but it works and that's all that really matters and I have used it a lot!
I don't like flipping a chassis all over the place just to work inside.
So this does that well and I can test it while it is in the cradle as well.
rvf263
Post by rvf263 »
guitarmike2107 wrote:thanks Tom
cheers
Mike
Mike,
Thanks for putting those plans together!
I'm getting ready to build one from them this week.
RvF
Sorry I misunderstood.
So Mike you are the author of those plans?
If so, good job, appear to be very well drawn. :D
Ron Worley
Post by Ron Worley »
Structo wrote:No I had built my cradle before I found those plans.
Tom- yeah, it was my attempt at a revolving cradle...... it's OK, but could work better...
Ron
C Moore
Post by C Moore »
I have never had the ability to hold the amp, at an angle, in a cradle, like some of you guys can with your rigs. I imagine, if available, that is a nice option. It is probably one of those niceties that you would really miss, if it were taken away from you. I would hate for you guys to see a picture of me with a amp "on end" so that I could work on it while the (power) tubes were installed. You know....with a 2x4 under the PT to keep the chassis "stable".
Thanks again for all the pictures and ideas.
Once you use one I think you would come to love it.
Less risk of damaging the tubes and when you power it up you can move the amp/cradle where your speaker cab is and measure some voltages.
drhulsey
Post by drhulsey »
These Panavise jaws mounted in most any kind of upright gives you 360 degree capability.
Tim
Greg
Post by Greg »
Greg
Greg
Post by Greg »
$ 31.00 at Micro-Tools through AMAZON...I think I will get these.
Greg
C Moore
Post by C Moore »
drhulsey wrote:These Panavise jaws mounted in most any kind of upright gives you 360 degree capability.
Maybe I am not looking at it the right way. It seems like this would only be good for working on a chassis that did not have tubes installed. Am I wrong? Can you put a Bassman chassis in this with the power tubes installed?
Thank You
greenbottle
Post by greenbottle »
I'd rather have a bottle in front of me than a frontal lobotomy.
drhulsey
Post by drhulsey »
hired hand wrote: ...Maybe I am not looking at it the right way. It seems like this would only be good for working on a chassis that did not have tubes installed.
Check out my pics on this thread:
https://tubeamparchive.com/viewtopic.php?t=8688
I think it will hold any amp chassis out there.
Tim
