"Babs" is finished!
mac0611
"Babs" is finished!
Post by mac0611 »
Here is "Babs" completed yesterday and fired up. She sounds awesome, and is dead quiet. I hope these files uploaded, I had problems yesterday. Thanks to Allyn, Dana, and Moose for all the help. I tried to upload individual pics, well under 5MB, and I can't get them to load.
Thanks Omar! Here they are fellas. :)
MooreCowbelle
Re: "Babs" is finished!
Post by MooreCowbelle »
Files? Looks like they didn't. :(
Allynmey
Site Admin
Post by Allynmey »
Only tiny files seem to upload. You can zip them up and upload them. The max zip file size is 5MB
Allyn
Omar
Post by Omar »
All file types are limited to 5MB. You should be able to upload the pictures as long as they are under the limit. The forum software will auto size them if the are too big and allow you to click on the picture for the full size view.
Also, uploading files can take a while especially if there are number of large files.
See example below.
Omar
Tone by misadventure
Allynmey
Site Admin
Post by Allynmey »
Omar, the autosizing doesn't seem to work. If you try to upload any thing originally bigger than 600X400 or so, It will look like its uploading, flash then it's gone! I end up having to zip files that are under 5 MB and uploading them. I will check my software (I use the same software) to see where to do this.
Allyn
Omar
Post by Omar »
Allynmey
The size of the original picture I posted was 2592x1944 so the resizing seems to work for me. What browser and operating system are you using? I'm using IE6 and XP SP2.
Omar
Noel Grassy
Darling Babs
Post by Noel Grassy »
Superlative build Mac! That looks like it rates some NOS Mullards . What tubes are you running her up with? Cheers, Noel
Allynmey
Site Admin
Post by Allynmey »
Omar wrote:Allynmey
Omar
Omar, I'm running the same as you. That's so weird! I run a board and use the same PHPBB2 as this forum and the attachments work fine. I've had this problem for a while and find that only small (600x400) upload in the .jpg or .gif format here. I wonder if it is letting you update due to your admin rights in the attachment manager? :?
Allyn
omar_test
Post by omar_test »
picture test
Omar
Post by Omar »
Ok, I think I found the problem. Give a try now and see if you guys can upload pictures bigger then 600x400.
Please let me know if you have any issues.
Omar
