So marcos, do you prefer the 330pf? Does it make a marked difference? If so, how would you describe the change?marcos wrote:Hi David,
the silver mica treble cap is out of the amp now (replaced it with a 330 pF silver mica), is labelled 510 pF, and looks unlike any of the caps available
these days.I have several caps from different manufacturers, my favourites are made by CDE I believe, and they all look different.Maybe when I get around to it I will post a picture of the cap, some of the guys here might know what it is.
New 70's style build up and running. (Thanks!!)
Re: New 70's style build up and running. (Thanks!!)
<i> "I've suffered for my music. Now it's your turn."</i>
Finally got it all cleaned up and in a cab.
I like my playing to be subtle and tasteful.....and my amps to be neither!
I love the looks of that amp, sweet.
what is the trick to mounting the chassis in the cab?
									My Daughter Build Stone Henge
In my case, I just made the cab to fit the chassis pretty tightly. I use the front aluminum trim strip as a front stop, and put the same trim on the back panel as a back stop. The amp doesn't actually bolt in at all, it just slides into place and is held there by the trim strips. Probably wouldn't do it that way if I was gonna sell it, but this one won't travel much. That said, it's in there good and tight, and it comes out easy. Important seeing as my amps always spend a lot of time on the bench anyway.selloutrr wrote:what is the trick to mounting the chassis in the cab?
I used cage nuts,selloutrr wrote:what is the trick to mounting the chassis in the cab?
there´s a picture in my topic
´another 70s style build´
http://img.photobucket.com/albums/v683/ ... G_0003.jpg
forgot to mention
it´s on the right side
close to the input jack
very nice!  the original's mounted from the top.. like the fenders.. right?
Very similar, except that Mr. D ran the screws through the top of the cab, outside the side walls of the chassis, then secured them to a lip underneath. The Nach chassis's don't quite have enough lip to pull this off.selloutrr wrote:very nice! the original's mounted from the top.. like the fenders.. right?
check out the corners of the chassis bottom.
if the bolts do secure to the lip... how much longer does the chassis need to be .. or move in the walls how far and still make it all work?
Yep, just like that. Here's how he did #40.selloutrr wrote:check out the corners of the chassis bottom.
found it
that was awesome we posted at the same time... you beat me by just a butt hair lol
NICE PIC!
									NICE PIC!
Hey, great minds think alike....selloutrr wrote:that was awesome we posted at the same time... you beat me by just a butt hair lol
NICE PIC!
