Ceriatone AH-50
Re: Ceriatone AH-50
Why get the AH50 kit if your going to strip all that out?
- Cathode Ray
FourT6and2
Re: Ceriatone AH-50
It's a Friedman Brown Eye clone. If you add a depth control, I recommend trying a 2200pF cap instead of 4700pF. Or anywhere in between really. Don't be afraid to experiment. But 4700pF might be to much.
Variable NFB is cool at first, but you'll probably find one setting you like and leave the pot set there. So it might make more sense to temporarily alligator clip in a pot for the NFB resistor and play around with it until you find a setting you like, then just solder in a resistor for that value.
- Cathode Ray
Re: Ceriatone AH-50
Thanks manFourT6and2 wrote: ↑Thu Dec 13, 2018 7:02 am It's a Friedman Brown Eye clone. If you add a depth control, I recommend trying a 2200pF cap instead of 4700pF. Or anywhere in between really. Don't be afraid to experiment. But 4700pF might be to much.
Yeah, I realize I'm adding the "thump" and "response" knobs.
I will try a 2200pF cap there.
I know you built these type amps before and was wondering.. did you wind up changing the clipping circuit components? Thinking of trying an asymmetrical clipping in that spot, maybe some germanium diodes or LED's, rather than the symmetrical clipping it has with the transistors or the diodes.
- Reeltarded
Re: Ceriatone AH-50
My honest opinion of clipping circuits is they all just sound like a similar fizz. I have tried every mixture you could imagine.
Transistors are just diodes. You get the same response and the same drop as any similar single diode just without spider legs all chopped off or wrapped. Pick dropping values and just go with it. I use 12v pair and 1N914 pair tailed together on a switch I wish I didn't install with a 25k pot I had room for to adjust the squash.
Spend valuable time with the meat of the amp and experimenting with mixers/dividers vs stage cathodes and bypass. These places are where the real stuff is happening. That amp has enough holes to never use a diode for pretend drive.
- Cathode Ray
Re: Ceriatone AH-50
I'm curious about that whole thing because I've never played a "Jose" style modded Marshall.Reeltarded wrote: ↑Thu Dec 13, 2018 1:21 pm My honest opinion of clipping circuits is they all just sound like a similar fizz. I have tried every mixture you could imagine.
Spend valuable time with the meat of the amp and experimenting with mixers/dividers vs stage cathodes and bypass. These places are where the real stuff is happening. That amp has enough holes to never use a diode for pretend drive.![]()
As you say, I may not like this type of clipping at all, and remove it or change it.
Thanks for the comments, guys
FourT6and2
2 others liked this
Re: Ceriatone AH-50
Some Jose-style mods sound fizzy. Others don't. I do hear a difference between zeners and transistors wired up as zeners. Not in the level of clipping, but in the character of it. There's also a difference in feel/character between types of zeners and transistors. It's subtle, though.
But yeah I would focus on getting the circuit right and then play around with the clippers. Or just add another gain stage.
- Cathode Ray
Re: Ceriatone AH-50
Agreed.FourT6and2 wrote: ↑Thu Dec 13, 2018 3:54 pm Some Jose-style mods sound fizzy. Others don't. I do hear a difference between zeners and transistors wired up as zeners. Not in the level of clipping, but in the character of it. There's also a difference in feel/character between types of zeners and transistors. It's subtle, though.
I know you've built quite a few Ceriatone kits. Do you usually change any components in them?
Like Wima caps instead of the ones supplied
FourT6and2
Re: Ceriatone AH-50
The ones I've built are not Ceriatone circuits. I just use the turret board and chassis for the layout. But yes, I've used like every type of resistor/cap you can think of since I source all the components myself.Cathode Ray wrote: ↑Thu Dec 13, 2018 4:03 pmAgreed.FourT6and2 wrote: ↑Thu Dec 13, 2018 3:54 pm Some Jose-style mods sound fizzy. Others don't. I do hear a difference between zeners and transistors wired up as zeners. Not in the level of clipping, but in the character of it. There's also a difference in feel/character between types of zeners and transistors. It's subtle, though.
Like Wima caps instead of the ones supplied![]()
- Cathode Ray
Re: Ceriatone AH-50
What iron are you liking for the Jose modded type of builds ?FourT6and2 wrote: ↑Thu Dec 13, 2018 8:10 pmThe ones I've built are not Ceriatone circuits. I just use the turret board and chassis for the layout. But yes, I've used like every type of resistor/cap you can think of since I source all the components myself.
..or is the stock Ceriatone OK?
FourT6and2
Re: Ceriatone AH-50
I've used Merren, Marstran, Heyboer, Classic Tone, etc. They all sound fine.Cathode Ray wrote: ↑Thu Dec 13, 2018 9:26 pmWhat iron are you liking for the Jose modded type of builds ?FourT6and2 wrote: ↑Thu Dec 13, 2018 8:10 pmThe ones I've built are not Ceriatone circuits. I just use the turret board and chassis for the layout. But yes, I've used like every type of resistor/cap you can think of since I source all the components myself.
- Cathode Ray
Re: Ceriatone AH-50
I sent Chris Merren an e-mail asking for a xformer for my 100W Plexi clone like 8 years ago...FourT6and2 wrote: ↑Thu Dec 13, 2018 10:16 pmI've used Merren, Marstran, Heyboer, Classic Tone, etc. They all sound fine.Cathode Ray wrote: ↑Thu Dec 13, 2018 9:26 pmWhat iron are you liking for the Jose modded type of builds ?FourT6and2 wrote: ↑Thu Dec 13, 2018 8:10 pmThe ones I've built are not Ceriatone circuits. I just use the turret board and chassis for the layout. But yes, I've used like every type of resistor/cap you can think of since I source all the components myself.
Still waiting on a response.
FourT6and2
Re: Ceriatone AH-50
Yeah, he takes forever. Go with Marstran thenCathode Ray wrote: ↑Thu Dec 13, 2018 10:37 pmI sent Chris Merren an e-mail asking for a xformer for my 100W Plexi clone like 8 years ago...FourT6and2 wrote: ↑Thu Dec 13, 2018 10:16 pmI've used Merren, Marstran, Heyboer, Classic Tone, etc. They all sound fine.Cathode Ray wrote: ↑Thu Dec 13, 2018 9:26 pm
Still waiting on a response.![]()
- Cathode Ray
Re: Ceriatone AH-50
It was right there in front of me the entire time.Reeltarded wrote: ↑Wed Oct 24, 2018 12:26 pmVan Halen's dirty secret is that the good records were all cascaded heads.
A clean little Fender amp head loaded with a resistive load, then line out into a 2203.
Holy Moley. There it is.
- Reeltarded
Re: Ceriatone AH-50
Yep. Anything he ever said should be ignored. Everything.Cathode Ray wrote: ↑Sun Feb 24, 2019 5:14 amIt was right there in front of me the entire time.Reeltarded wrote: ↑Wed Oct 24, 2018 12:26 pmVan Halen's dirty secret is that the good records were all cascaded heads.![]()
Holy Moley. There it is.![]()
