Hot rod deluxe problem
blu4x5
Post by blu4x5 »
its a green board printed 1996.
issue: turn it on/standby i can feel it slightly vibrating. take off standby still slight vibrating and there is a slight crakling. just put in new 6L6s havent change preamp yet. where should i look. i know how to dissipate caps. not scared to poke around a little bit. got a chopstick and poked around didnt locate problem. not sure i'm looking in right area.
jelle
Re: Hot rod deluxe problem
Post by jelle »
What is this post doing here*??
blu4x5
Post by blu4x5 »
i thought this is where it should go am i wrong?
No the post should be in the technical section since the amp is a Fender not discussion regarding a Trainwreck amp. :)
vibratoking
Post by vibratoking »
This is posted in the wrong place and should be moved.
Zippy
Post by Zippy »
blu4x5 wrote:its a green board printed 1996.
(Yes, this was originally posted in the wrong forum - better to gut the amp and build a Rocket from it.) :lol:
It sounds like your "vibration" is nothing more than the transformers humming.
Does the crackling keep going after flipping the switch for a while? If you just changed tubes and the crackling started, it's possible that the tube sockets are loose. Are the new tubes the same brand as the old tubes? I'm wondering if the pins are smaller on the new tubes or dirty and not making good contact.
Try to give a better (different) description of what you are experiencing, what changes were made, and when the problem started.
Zippy
Post by Zippy »
vibratoking wrote:This is posted in the wrong place and should be moved to the Trainwreck Discussion section.
It's not a TrainWreck - doesn't need to go to TrainWreck Discussion.
Should be in Shop Talk - Technical Discussion.
