Wah to volume switch
greiswig
Post by greiswig »
Wondering if anyone here has tried to make it so that their wah pedal, when not on the wah setting, acted as a volume pedal? It'd sure be nice to have that second use for it...
-g
davent
Re: Wah to volume switch
Post by davent »
There's a schematic and pcb for adapting a Crybaby to a wah/volume pedal at Tonepad. I haven't tried this but with the treadle's limited travel i would think the volume function would be pretty compromised.
http://www.tonepad.com/getFile.asp?id=59
dave
jjman
Post by jjman »
Many inventions are the combination of 2 things. In this case I think the ohm value of the pot could be an issue. Get a dual pot with 2 different values (custom made ?) and it seems very possible to me.
selloutrr
Post by selloutrr »
with dual pots it's no more then wiring the pot.
the downside would be the volume loss of increase you would get when switching from effect to effect.
My Daughter Build Stone Henge
greiswig
Post by greiswig »
Thanks guys! The dual pot idea is one thing I had thought of. I've done that before: remove the element from one of the two pots and replace it with a different value to make my own custom. I might try that in my Teese.
Guess I was hoping that someone else was already selling something that did both well. I know there was one manufacturer who did, but I don't think it was very well thought of.
-g
selloutrr
Post by selloutrr »
morley made a volume wah back in the 70's / 80's the big silver style. but you had to select between them via a footswitch on the deck.
