Power transformer shield
dynaman
Post by dynaman »
I've got a Fender PT with a wire for a "shield". Where do y'all typically connect it for lowest noise? Power supply ground? Earth?
Re: Power transformer shield
I've always put it to chassis ground.
ChrisM
Post by ChrisM »
Main's ground.
Ground the shield with the center taps or main ground as stated.
dynaman
Post by dynaman »
OK, I'll just ground it with the mains. Thanks.
David Root
Post by David Root »
I ground that with the HT CT/heater winding CT/power tubes cathodes.
Cliff Schecht
Post by Cliff Schecht »
David Root wrote:I ground that with the HT CT/heater winding CT/power tubes cathodes.
This is what I would do. Tying stuff to the mains ground is a no-no.
Cliff Schecht - Circuit P.I.
Pretty sure both of us were referring the main ground of a amp where I ty all the center taps and main filter cap. That is where I ground the shield.
I have a separate ground for the green ground wire USA.
VacuumVoodoo
Post by VacuumVoodoo »
Correct name for that shield is "protective screen" and it should connect directly to safety ground.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
As in the IEC safety ground?
