1 or 2 bias pot?
sergio
1 or 2 bias pot?
Post by sergio »
In an amp with 4 tubes is better use 2 bias pot for a fine adjustment and balance two pair tube?
LooseChange
Re: 1 or 2 bias pot?
Post by LooseChange »
Any way to individually control the bias on your power tubes is better than one universal control.
The best would be a pot for each tube. Have you ever played an amp with a pair each of 6L6's and 6V6's? How about four unmatched NOS RCA? EL34's and 6550's? One each of each type listed above?
Luthierwnc
Post by Luthierwnc »
With 4 tubes you can usually mix and match to get the sides tolerably balanced. sh
Firestorm
Post by Firestorm »
The data sheets for KT66, KT88, etc. say that it is "essential" to have a separately adjustable bias supply for each tube. Of course, they say a lot of other stuff that we ignore ... :wink:
llemtt
Post by llemtt »
Balancing currents in the two halves of the OT is very important when max headroom and bandwidth is mandatory: for instance bass amps!
In a guitar amp isn't always a good idea unless you do balance also the PI levels to preserve symmetrical clipping of the output tubes.
teo
sergio
Post by sergio »
Well , there are different ideas about this.
