Thanks Tony. Likewise...
I see it as some kind of balance... Personally, I think the part selection is crucial as you say, especially where the signal path is concerned. Hence, I have a bag of 6PS caps sitting on my desk waiting to tested and measured. As you mentioned, it starts to look pretty straightforward as you break it down into its constituent parts but then you put all these gain stages together and it becomes another kind of beast altogether. Another thing I will be doing is using carbon film resistors... some people don't seem to think very highly of them but when Dumble used them, it wasn't because he couldn't get hold of metal film. I think its healthy to assume that everything that is there in the 124, is there for a reason. I may not understand those reasons but that is no excuse to go ripping it apart with ill considered, baked-in changes. The fundamental circuit is to be maintained as much as possible and any mods, should be switchable so that with them out of the circuit, what remains is the essential 124 "neurology," as unabridged and unadulterated a it can be. I agree, it really makes sense to stick with the parts list as much as possible. The power section has to be overhauled though, and Martin's precision power supply seems a no-brainer. As a sidenote, I recently found some Ruby caps and I am going to use these in my Tweedle Dee in place of the F&T's that are in there at the moment. Maybe filter caps do have an effect on tone, but if so it is probably quite subtle, if noticeable at all. I will be getting back into that project and sorting it out before I order the power supply caps for 124 so it's a chance to test for any differences that may occur.
I do have one question which has been bugging the hell out of me, perhaps you could answer this one...
In the photos of the 124 which I posted earlier today, it's clear that D used a different type of resistors for the first triodes' cathodes of both the clean and overdrive channels. Gil's sketch [Edit: the sketch was made by Bill, if I understand correctly] marks all four as 1.5k but there is a distinct difference between the fatter, larger resistors on the input side, second triode ( pin 8 ) and the smaller RN65 form of the white resistors on the output side ( pin3 ). The 123 schematic you posted, also has different values for the cathodes of single tubes. For the moment, I don't fully understand why that might be necessary, though if I recall correctly, it has something to do with the Miller capacitance of the first and second triodes. To me, the value of the resistors looks quite important. Could it be that the input cathode resistor has a higher rated Wattage? Or is a different type, ceramic wirewound or so on? It's a shame we don't get to see it in its naked state without all the (expletive) goop, but even that was there for a reason. If anyone has any ideas there, it would be good to hear them.
Yeah, so, someone once told me that as more mods are added there is more chance the endeavor will go south. I think it may have been you, in which case, thank you, I agree. The Tweedle Dee entailed a fair bit of reading up before and after I put the parts on the bench to be assembled, but the 124 is next level stuff. I don't want to be somebody's kit-builder. I really want to understand this Voodoo Magic...
Stephen
