New 70's style build up and running. (Thanks!!)
crbowman
Re: New 70's style build up and running. (Thanks!!)
Post by crbowman »
marcos wrote:Hi David,
the silver mica treble cap is out of the amp now (replaced it with a 330 pF silver mica), is labelled 510 pF, and looks unlike any of the caps available
these days.I have several caps from different manufacturers, my favourites are made by CDE I believe, and they all look different.Maybe when I get around to it I will post a picture of the cap, some of the guys here might know what it is.
So marcos, do you prefer the 330pf? Does it make a marked difference? If so, how would you describe the change?
crbowman
Post by crbowman »
Finally got it all cleaned up and in a cab.
I like my playing to be subtle and tasteful.....and my amps to be neither!
8)
I love the looks of that amp, sweet. 8)
selloutrr
Post by selloutrr »
what is the trick to mounting the chassis in the cab?
My Daughter Build Stone Henge
crbowman
Post by crbowman »
selloutrr wrote:what is the trick to mounting the chassis in the cab?
In my case, I just made the cab to fit the chassis pretty tightly. I use the front aluminum trim strip as a front stop, and put the same trim on the back panel as a back stop. The amp doesn't actually bolt in at all, it just slides into place and is held there by the trim strips. Probably wouldn't do it that way if I was gonna sell it, but this one won't travel much. That said, it's in there good and tight, and it comes out easy. Important seeing as my amps always spend a lot of time on the bench anyway.
two tone
Post by two tone »
I used cage nuts,
there´s a picture in my topic
´another 70s style build´
http://img.photobucket.com/albums/v683/ ... G_0003.jpg
two tone
Post by two tone »
forgot to mention
it´s on the right side
close to the input jack
selloutrr
Post by selloutrr »
very nice! the original's mounted from the top.. like the fenders.. right?
crbowman
Post by crbowman »
selloutrr wrote:very nice! the original's mounted from the top.. like the fenders.. right?
Very similar, except that Mr. D ran the screws through the top of the cab, outside the side walls of the chassis, then secured them to a lip underneath. The Nach chassis's don't quite have enough lip to pull this off.
selloutrr
Post by selloutrr »
check out the corners of the chassis bottom.
selloutrr
Post by selloutrr »
if the bolts do secure to the lip... how much longer does the chassis need to be .. or move in the walls how far and still make it all work?
crbowman
Post by crbowman »
selloutrr wrote:check out the corners of the chassis bottom.
Yep, just like that. Here's how he did #40.
selloutrr
Post by selloutrr »
found it
selloutrr
Post by selloutrr »
that was awesome we posted at the same time... you beat me by just a butt hair lol
NICE PIC! :)
crbowman
Post by crbowman »
selloutrr wrote:that was awesome we posted at the same time... you beat me by just a butt hair lol
NICE PIC! :)
Hey, great minds think alike....
