Check out these clips...
Funkalicousgroove
Re: Check out these clips...
Post by Funkalicousgroove »
That amp is the 70's style circuit, 100K slope, 100K/1k5 plate/cathodes, Funky OD entrance network.
Lance isn't using a loop , but he is plugged into the FET input.
5uf bypass caps all around, 100W amp w/1/2 power switch. JJ Pre's Tung-sol 6l6's
Brandon
JimiB
Post by JimiB »
What is that? Havent heard that term before. Is that a dumble term?
:lol:
I love my rail tone amp!
Funkalicousgroove
220K/500pf to ground, 1.2M in series, 33k to ground
ER
Post by ER »
What's the PT bias tap voltage on the 1977?
-ER
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
Looks like the Pre-OD network showed up in the Kitty Hawk clone as well...
Funkalicousgroove
ER wrote:What's the PT bias tap voltage on the 1977?
-ER
Twin Iron 330-0-60-330
dr. who
Post by dr. who »
"but he is plugged into the FET input"
Were there any ODS made that had one input and had the fet switchable by a footswitch like the SSS?
Funkalicousgroove
not that I know of
stratcat62
Post by stratcat62 »
ER wrote:One guy mentioned that it was close to the sound Steve Kimock gets with his dearmond, and the little SE dearmond I built does a pretty job at getting that sound.
Any ideas on how Kimock pads down the output to go to a bigger amp?
-Erik
If you run out from the speaker jack on the small amp to a dummy load that has a line out with volume adjustment (ex. Hot Plate), then you don't need a speaker. Kimock runs his DeArmond combo speaker and all and has a cable running from the +/- connectors out to his speaker to line level attenuator. I've run amps through the Hot Plate into the input of my Twin with the line level way down, which pretty much turns the Twin into a power section for the little amp.
hitchcaster
Post by hitchcaster »
UltraHookedOnPhonix wrote:Looks like the Pre-OD network showed up in the Kitty Hawk clone as well...
they didn't get the memo on the heaters though :cry:
talbany
Post by talbany »
Yeah you've heard of the term HRM for Hot Rubber Monkey!!
This is the FMN Funky Monkey Network!!!...LOL!
T
crbowman
Post by crbowman »
Sorry for coming in late here guys but I REALLY love the tone on the clip. Brandon, if you don't mind, what were the pot values? Classic 250K/100K/250K or the older 70's 500K/250K/1M?
Funkalicousgroove
send a PM, Big Brother is watching
mlp-mx6
Post by mlp-mx6 »
Funkalicousgroove wrote:send a PM, Big Brother is watching
Not if his name is chimeboss! He's been banned, I believe.
Me: Just one more...
crbowman
Post by crbowman »
Maybe the "Big Fella" himself. :D
