Moderators: pompeiisneaks , Colossal
sunny
Posts: 17 Joined: Wed Dec 04, 2013 11:51 am
Post
by sunny » Fri Dec 13, 2013 7:53 pm
Thanks Mark, and nice build bye the way!
Sounds great, I cant wait to hear some samples!!
Paul
Posts: 14036 Joined: Wed Jan 16, 2008 2:19 am
Post
by M Fowler » Fri Dec 13, 2013 8:31 pm
Yeah about those sound samples, I've been meaning to set up a mixing station for about 5 years or so
amplifiednation
Posts: 2091 Joined: Sun Dec 26, 2010 6:19 pm
Post
by amplifiednation » Sat Dec 14, 2013 4:09 am
I've got a set of faceplates for that chassis but there are amp nation logos all over them!
If you want the design files give me a shout I'll help you get some plates made
T
Amplified Nation
www.amplifiednation.com
@ampnation
Post
by M Fowler » Sat Dec 14, 2013 5:49 am
Taylor I emailed you thanks.
sunny
Post
by sunny » Mon Dec 16, 2013 2:13 pm
Mark, do you have some kind of ''simple'' layout like this one for example
https://tubeamparchive.com/download/file.php?id=30708 ?
It's a little blurry for me when i look at the schematic and the pictures
I am not a pro like most of the guys here. It would make it a lot easier for me
it's hard to say what is going on underneath the boards.
Paul
Post
by M Fowler » Mon Dec 16, 2013 4:32 pm
sunny wrote: Mark, do you have some kind of ''simple'' layout like this one for example
Paul
I'm sorry I do not have a layout for you to go by.
I had to use the schematic and photos on my build.
Post
by M Fowler » Mon Dec 16, 2013 4:54 pm
Under the tone board is mostly ground connections to all the preamp cathode resistors/bypass caps.
The other connections could be done from the top if you wanted. I know I don't like wiring boards underneath like this, twice as hard in my opinion.
The PS board could be built differently too.
Post
by M Fowler » Sun Jan 26, 2014 10:35 pm
Added new faceplate looks better now.
dorrisant
Posts: 2790 Joined: Tue Sep 21, 2010 1:27 pm
Post
by dorrisant » Fri May 16, 2014 5:18 pm
Mark,
What were your voltages? I found some handwritten documentation that had some... Just curious if you know off-hand.
After your glorious comments I have to build this circuit. Good looking build!
Post
by M Fowler » Sun May 18, 2014 3:01 am
dorrisant wrote: Mark,
Tony I will have to take voltages again and write them down and post.
dorrisant
Post
by dorrisant » Sun May 18, 2014 4:39 pm
Thanks Mark. You are a machine!!!
beasleybodyshop
Posts: 1089 Joined: Tue Jul 02, 2013 12:51 am
Post
by beasleybodyshop » Thu May 29, 2014 6:24 am
I have been using my horribly meager layout skills to come up with a layout for this amp based on the photos in this thread and Aaron's schematic. Please forgive the squiggly lines, inkscape is a bitch to get smooth lines.
This layout is not complete, so use at your own risk! Any feedback for correctness would be fantastic.
Aaron
Posts: 643 Joined: Wed Feb 08, 2006 1:07 pm
Post
by Aaron » Thu May 29, 2014 6:41 am
Nice work on the layout. It takes me about the same time drawing a layout as it does to build it!
Aaron
beasleybodyshop
Post
by beasleybodyshop » Thu May 29, 2014 6:43 am
thanks Aaron! Your schematic was invaluable. I wouldn't have been able to do this without it and Marks guidance.
dorrisant
Post
by dorrisant » Thu May 29, 2014 3:42 pm
Nice looking layout! What are you using to draw that up with?
