uf values for PS filter caps
Markusv
Post by Markusv »
Quick question for anyone who is willing
How do designers arrive at the uf value for powersupply caps?
I understand the voltage rating, but what about capacitance?
I understand that there is some variation in different clones especially with the 80uf caps ( 1st in line)
Best regards,
MarkusV
.........Now where did I put it?
teleamp
Re: uf values for PS filter caps
Post by teleamp »
Its a balance of a couple of things. The more capacitance the less AC ripple noise, but too much and the amp will sound less musical. Also, the amount of capacitance will play a role in tight or loose bass response. Those are the results of what I have found with my experimenting.
MikeY
What!
keithrick
Post by keithrick »
Markusv, I would look at Randall Aiken's site. He has a tech page section that covers alot of tube amp theory. I did alot of reading before my first build and slowly, it is starting to sink in.
:idea:
Markusv
Post by Markusv »
teleamp wrote:Its a balance of a couple of things. The more capacitance the less AC ripple noise, but too much and the amp will sound less musical. Also, the amount of capacitance will play a role in tight or loose bass response. Those are the results of what I have found with my experimenting.
MikeY
Thanks, that was loosely my understanding too. I guess I will fool around and see for myself
Markus v
Markusv
Post by Markusv »
keithrick wrote:Markusv, I would look at Randall Aiken's site. He has a tech page section that covers alot of tube amp theory. I did alot of reading before my first build and slowly, it is starting to sink in.
:idea:
Keithrick
Good suggestion
I'll do that too. I have been reading as much as possible, and it does slowly make more sense- I have NO tech background. Given my fascination with these things, I wonder what I was thinking when I chose my career.
Many thanks
Markus V
Broz
Post by Broz »
Markusv, look at the power supply filtering and decoupling network articles from the audio classroom series at http://www.audioxpress.com/resource/aud ... /index.htm
These are really good.
Broz
Moose
Post by Moose »
Play with this:
http://duncanamps.com/psud2/index.html
It might help some of the reading sink in. You can change values in a power supply and see how response changes graphically. It helped me to visualize.
Markusv
Thanks for the help Broz & Moose
Post by Markusv »
Thanks for those suggestions-
I'l play around and learn as much as possible.
This is just the best forum. I've never experienced such goodwill and support anywhwere else. I hope one day I may be able to contribute meaningfully as currently it's just me reeling in info on my end
Regards,
Markus V
