Problem with startup
johnnyreece
Re: Problem with startup
Post by johnnyreece »
martin manning wrote:or just disconnect the feedback.
That's what I always do if NFB wiring is a concern. It's easily reversable, and if that doesn't fix your problem, you know something else is going on. Then, fix any other issues, and reconnect the NFB. If you have an issue then, you know that's the problem, and you can switch the primaries.
The routing of the NFB wire could be the problem, so disconnecting the FB is not as conclusive as swapping the leads, but it will tell you that the problem is with the FB loop.
jckid649
Post by jckid649 »
delete
jckid649
Post by jckid649 »
Swapped the primaries. Problem solved. Thanks for the advice.
