Asteroid Layout
Noel Grassy
Re: Asteroid Layout
Post by Noel Grassy »
OH, cool.
rhinson,
Thanks for reminding me I'm building the 60. :oops:
Maybe you can tell me if the stand-offs and tube socket fasteners were
#4-40 TPI or #6-32 TPI. Mine are drilled & countersunk already but I
have this nagging OCD feeling.
I appreciate the help, each and every time.
NG
breakfastbuddy
the astorid
Post by breakfastbuddy »
i also want the schem and the layout please
esp-joh@online.no Espen from Norway
Roe
Re: Asteroid Layout
Post by Roe »
btw, I and a friend are building another comet now
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
gearhead
Re: Asteroid Layout
Post by gearhead »
Anyone have the layout for the Konkord?
telekingdom
Re: Asteroid Layout
Post by telekingdom »
I would like to build one of these if someone would be kind enough to send me the information...
Many thanks.
Kern
EDIT: Thanks to those who helped a fellow builder and sent the files!
Roe
Re: Asteroid Layout
Post by Roe »
the second comet started up without problems! no problems with noise or ghosting. had to increase the bias resistor to 10k to get in the right bias range though
4x12" w/H75s
Roe
Re: Asteroid Layout
Post by Roe »
4x12" w/H75s
bnwitt
Re: Asteroid Layout
Post by bnwitt »
Roe wrote:had to increase the bias resistor to 10k to get in the right bias range though
Do you mean the 470 ohm 1 watt resistor was increased to 10K?
Great things happen in a vacuum
Roe
Re: Asteroid Layout
Post by Roe »
yes, exactly. this depends on the tubes of course. but 10k gave a much more usable range than 470. the pin 5 voltage was about -78v with the 470 and roughly -50v with the 10k
4x12" w/H75s
bnwitt
Re: Asteroid Layout
Post by bnwitt »
Roe wrote:the pin 5 voltage was about -78v
Wow! What PT did you use? What is your B+ voltage at the standby switch? I see in your other post that you are in a 240V part of the country.
tele caster
Re: Asteroid Layout
Post by tele caster »
Giving this a bump. Anyone have these files so I can have a look? Probably not going to build this, just want to have a look. Thanks.
tele caster
Re: Asteroid Layout
Got it, thanks.
argonaut
Re: Asteroid Layout
Post by argonaut »
Hi, If it's not too much trouble, could someone shoot me the files as well? Have a long winter ahead...
Edit: Got it, thanks!
tictac
Re: Asteroid Layout
Post by tictac »
Ditto,
Please.... :P
tele caster
Re: Asteroid Layout
PM me if you didn't get it .
