el 34 in a 18 watt tmb
mark enger
Post by mark enger »
what would it take to run a el 34 instead of a el84 in a 18 watt marshall tmb build, whats heater voltage on a el34, what resistor would run the bias, a opt that runs a el 34 would that work with the 34 it a 8 ahm only opt??? if this wont wotk or is to complacated what a cool el 12ax7 build will a pt meant for a 2 el84 amp even run a set of el34??
benoit
Re: el 34 in a 18 watt tmb
Post by benoit »
mark enger wrote:what would it take to run a el 34 instead of a el84 in a 18 watt marshall tmb build, whats heater voltage on a el34, what resistor would run the bias, a opt that runs a el 34 would that work with the 34 it a 8 ahm only opt??? if this wont wotk or is to complacated what a cool el 12ax7 build will a pt meant for a 2 el84 amp even run a set of el34??
Heater current alone would likely be a problem. 2xel84 would draw about 1.5A. That would only run heaters on ONE el34.
"I never practice my guitar. From time to time I just open the case and throw in a piece of raw meat." --Wes Montgomery
