Stevem wrote: ↑Sat Jul 26, 2025 1:42 pm
I think it’s best if the owner wants a trouble free amp is to get a new PT.
Mosfets can introduce a fair amount of noise if not mounted far enough away from gain stages and or grid wires.
A common stand up type for a hot rod deluxe isn’t too expensive and a search might find a remove original one from a amp that got a upgrade.
Good advice, Steve. In general, it's easier to make simple things more reliable. A single, properly sized PT would be simple and probably more reliable.
MOSFETs are a two edged sword, like so many "amazing" things. They have huge input impedance, high voltage and current capabilities, and very high frequency response, any of which can get you into trouble if you don't mange them properly. But if you do manage them properly, they can solve many problems.
@half-smith: you have two easy choices of places to put a MOSFET amplified zener. The issues are how to get the heat out of it, and whether you need two of them.
A MOSFET in the rectifier return offers easy(-ier) heat-sinking if you can just bolt the drain of an N-channel device to the chassis, forcing it to be at DC ground. Your power transformer doubler etc. makes this difficult to do in the easy-peasey way that FWB or FWCT setups use.
You could put a MOSFET zener either in the B+ high side of the final filter caps or in the low side. The high side is simple, but requires a heat sink that floats on top of B+.
The low side means that you could move the circuit "ground" to the drain/(+) end of the MOSFET zener, and tie the source/(-) end of the MOSFET zener to the negative end of the capacitors you have filtering the power supply now. The rectifier setup you have now is only "grounded" because you have the negative end tied to the point you have designated as circuit ground. You could stick the MOSFET zener between the negative end of the rectifier setup and your circuit ground and then the DC voltage to the circuit would be lower by the MOSFET zener voltage. But you would also likely need another filter cap between B+ and circuit ground to act as a reservoir cap for AC signal reasons. This is more complicated, but would allow an N-channel MOSFET to have its drain on the chassis/ground for heat sinking.
Mark Twain
