Tremorocket 2xel84
Re: Tremorocket 2xel84
It blinks witht the rate of the tremolo.I just had it in there when I was troubleshooting to make sure the oscillator was working.The regualur cathode resistor and bypass cap are in there now.
That LED would be cool on the front panel if I had a way to make it stop blinking when the tremolo is off.I
Here's a link bout the cathode LED Its at the bottom of page
http://www.valvewizard.co.uk/trem1.html
Ok guys I took the tremolo out.It wasn't as great as I let on.I have several other amps that do it better.
I tried RJ's gain stage http://www.rjguitars.net/Rocket_Booster.html
It sounded incredibly shrill .I've done some things to roll of treble .Plate bypass cap,Playing with coupling caps.Lower gain tubes etc.but I'm finding no love.
Perhaps I just should leave good enough alone ?
Blackburn
Post by Blackburn »
Did you just create the trem circuit from your own design or did you base it off something else?
I used the 6G3 trem.It was ok.It worked good besides a little thumpin when both controls maxed.But like I said I have other amps that do trem better.
I really like the Idea of having more gain by turning a knob and having the amp back to stock by turining the knob to zero I just can't get it to sound good.
Update.The rocket booster is sounds good now"I'm not sure why.I did change out the coupling caps and switch the layout up a little. ANd added a plate bypass cap.I think the booster sounds really good now.I have an extra hole now I'm thinking MV.
I still haven't got a pilot lite for it. :oops:
