drop 6.3 to 5v for recto
mark enger
Post by mark enger »
Is it possable? Thanks mark
tubeswell
Re: drop 6.3 to 5v for recto
Post by tubeswell »
Voltage divider? (You'll lose a bit of current)
How about a couple silicon diodes of the proper current rating?
It would drop 1.2v
rdjones
Post by rdjones »
Don't try this on a typical guitar rectifier tube.
The filament is connected to B+.
rd
Yeah, you're right. :oops:
mark enger
so no not possable, ill go ss the. i have some ss plug ins i could use being the the sockets there already, now for sag R maybe a sag control? mark
Jana
Post by Jana »
How about putting a 0.68 ohm, 5 watt resistor in series with the leg of the 6.3 volts that is not common with the B+? That should drop about 1.3 volts with a 2 amp load.
VacuumVoodoo
Post by VacuumVoodoo »
Both legs are common with B+, there's 5V AC riding on B+ if you look closely with an oscilloscope.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Jana
Post by Jana »
Yes, I understand that the 5v winding rides at the B+ level. However, the B+ would not be going "through" the dropping resistor.
VacuumVoodoo
So, what is the problem with additional max 250mA when you already are pulling 2 or 3 amps through that resistor? You need a 5W or 8W resistor anyway. Any minute sag this introduces is only of academic interest , if any at all.
Aleksander Niemand
Zagray!-review
Suppose you experienced a short somewhere on the DC side of the HT... If that momentary (until a fuse or something else opens up) surge current comes through the rectifier's filament, maybe it would take the rectifier out too?
Prairie Dawg
Post by Prairie Dawg »
Why not use 6v rectifier tubes? 6CA4, 6AX5. 6X4 and a number of loktals are six volt, or say 2 3dg4s in series?
If you believe in coincidence you're not looking close enough-Joe leaphorn
renshen1957
Post by renshen1957 »
Prairie Dawg wrote:Why not use 6v rectifier tubes? 6CA4, 6AX5. 6X4 and a number of loktals are six volt, or say 2 3dg4s in series?
+1 :D
