VVR in Liverpool
VVR in Liverpool
Hey Guys,Im probably being repetitive here.Can anybody direct me to  vvr installation pictures in a Liverpool.Cant wait too put it in,Thanks,Mikey
						VVR in Liverpool
Well I did get some instructions from Dana.It looks like a bit more work than the garagetale guy shows.I still would like to see a picture of a Liverpool with one or a least a rocket.
 Patience Mikey
				Gibsonman63
Re: VVR in Liverpool
See if this helps.  Compare Dana's instructions with the attachments.  This is really the easy one to install because of the cathode biasing of the power tubes.  The VVR goes in the power supply string and you add a couple of blocking capacitors.  I moved the resistor from the input jack to the first preamp tube.
				Gibsonman63
Another couple of shots.  The third capacitor from the left is the blocking cap between C6 and V1a, pin 2.  Note that mine is a little different because I paralleled the first preamp stage so on the picture it is wired to the second preamp tube.
				Gibsonman63
BTW, I used the thermal compound on mine because I assumed that it was required.  There is another recent thread where Dana makes a compelling arguement for not using the thermal compound.  Mine works fine with it.
						vvr in Liverpool
Thank you very much,Im going to work on it today and Ill post some results,In the mean time I better look into the thermal glue, Is artic silver five OK for the VVR?,Mikey
				markr14850
Re: vvr in Liverpool
Probably not. AFAIK, it's electrically conductive.ampmike wrote:Is artic silver five OK for the VVR?
You might want to try a sil-pad instead. Unlike mica, they don't need thermal grease.
Here are a few that fit a TO-3P casing:
http://www.mouser.com/Thermal-Managemen ... 3p&FS=True
Here are a few pics of a Liverpool (Ginger Clone) amp I built 6 years ago in 2006. Ginger was Ken's first Liverpool and had a 1/2 power switch that really wasn't all that usefull. I removed the 1/2 power switch and installed the older VVR2. If you go with the smaller filter caps you can just squeeze it in. The newer smaller VVR is easier to mount. BTW this amp has been used a lot over the years and the VVR is still functioning without fail.
						vvr in Liverpool
Thank You Dana,Thanks to all you guys,I really feel the Liverpool is my favorite.Its just right for me and I cant wait or maybe my family cant wait for me to install the VVR.Dave aka Colossal is helping me install the vvr.Happy 4th to all of you here at TAD.These pictures are awesomeI will eventully switch over all my amps to vvr"s.!!!!Mikey    Dana,Is that a bias pot on your board?
Dana, thanks for posting the photos! Sweet build. The photos will make the install so much easier for Mike. [Pointing at the photos above...] Mikey, we need to do that to your amp!ampmike wrote:Thank You Dana,Thanks to all you guys,I really feel the Liverpool is my favorite.Its just right for me and I cant wait or maybe my family cant wait for me to install the VVR.Dave aka Colossal is helping me install the vvr.Happy 4th to all of you here at TAD.These pictures are awesomeI will eventully switch over all my amps to vvr"s.!!!!Mikey Dana,Is that a bias pot on your board?
- Reeltarded
lol Mike is all hyped up and raring to go on this.. just a guess.
No, That is a trim pot I installed in place of the 150k to dial in the third gain stage. it also has an adjustable line out on the back.ampmike wrote: Dana,Is that a bias pot on your board?
