ok thanks for your explanation!. another question , I see your orange drop caps  marked on a side, why?
						100w ods
Re: 100w ods
Thanks a lot!zimm wrote:Thanks! Good eye, that is Ampeg cloth I had laying around from an older project. The zener schemo is in this thread:
https://tubeamparchive.com/viewtopic.php?t=2818&start=0
 Peace,
Markus
Re: 100w ods
They are marked to show the polarity of the cap, although some are marked on two sides because I measured the caps once with a meter/foil and marked them, then read a blurb on the Aiken site about using a scope so I tried that and some of the results were different so I wound up marking them again. I went with the orientation based on scope marked caps but in all honesty Im not sure how accurate it was and Im not super concerned about it.
						Re: 100w ods
Hi zimm , can you post the link of Aiken where speak of this method?
Re: 100w ods
http://www.aikenamps.com/
click
Tech info>Advanced(Aiken)>"Where to connect the outside foil on capacitors"
						click
