BC Components/Vishay Cap series?
Can anyone tell me which BC Component series this electrolytic comes from (see attached photo)??. I tried contacting Vishay/BC but they bail at 4:30p. I *think* it may be the 118 series but can't confirm since the data sheets for any of their products never have a decent photo of the actual cap, just a useless line drawing with no features. This cap is stamped with the following:
+77 (or +LL)
118KO
BC
10µ M
200V 125oC
250V 85oC
About 1" x 5/16"d
Thanks for any help in advance.
+77 (or +LL)
118KO
BC
10µ M
200V 125oC
250V 85oC
About 1" x 5/16"d
Re: BC Components/Vishay Cap series?
Yep, 118 AHT.
http://www.vishay.com/docs/28334/118aht.pdf
KO stands for caps manufactured in Klagenfurt, Austria, from 2006 on (older series had HP for Zwolle, Netherlands)
Excellent! Thanks a lot FYL! Much appreciated.FYL wrote:Yep, 118 AHT.
How do they compare to the 041's
Rich, do the 041s also have spiral twisted blue aluminum casings? Just bigger voltage handling than the 118s, right?Rich M wrote:How do they compare to the 041's
It's strange. I bought a bunch recently from a Vishay distributer and the 10uF/160V ones had the transparent blue wrapping but the 33uF/450V ones had an opaque blue wrapping and said BC/Vishay onthey. My guess is Vishay is trying to make their product line look more visually consistent, but I'm not sure.
[img:578:1020]http://webpages.charter.net/rmweb/Parts ... F-160V.jpg[/img]
Diffrent caps for different uses.How do they compare to the 041's
118 AHT: low to mid voltages, 125°C ratings
041 - 043 ASH: mid to high voltages, 85°C ratings
Small dia caps are wrapped spiral-style, large ones use std. sleeves.My guess is Vishay is trying to make their product line look more visually consistent, but I'm not sure.
I have a older 041 33uF/450V cap that has the transparent wrap. I think this is the wrap from the old Philips days.
[img
678]http://webpages.charter.net/rmweb/Parts ... --450V.jpg[/img]
[img
422]http://webpages.charter.net/rmweb/Parts ... ---60V.jpg[/img]
[img
[img
Thanks for the photos, very helpful. So is this one current production 041? [img
The 118s I got came from Metroamp and are 10µF/200V. Going into a standard Marshally bias circuit.
How do you guys like the 041s as far as quality/consistency/failure rate/ESR etc?
Half a dozen brands and maybe twice as many factories gradually consolidated into a single entity part of the Vishay empire...I think this is the wrap from the old Philips days.
041's are good quality industrial-grade caps.How do you guys like the 041s as far as quality/consistency/failure rate/ESR etc?
Datasheet:
http://www.vishay.com/docs/28329/28329.pdf
That is the older of the two.Colossal wrote:Thanks for the photos, very helpful. So is this one current production 041? [img678]http://webpages.charter.net/rmweb/Parts ... --450V.jpg[/img]
Thanks Rich, good to know. I appreciate all the help. Many thanks to you too FYL.Rich M wrote:That is the older of the two.
