What im doing is a plexi in a tweed chassis, its real cramped, only 4 inches wide, and im using a PPIMV.
The MV pot sits directly opposite the centre of the power tubes. That also correlates to between the grid coupling caps. As im feeding the caps directly to the dualgangpats, just thought instead of running wires over the top or under board, using very short lead to the board, then 1.5K across the board, short lead down to the tube.
Im gonna try this anyways, if it ends up with a little oscillation (if i can hear it) then i can attach them directly. Just trying for a really really neat look.
Can still use that spot to run jumoers on the board i guess, then a grid R from board to socket. Its that tight i can run a Grid R from the turret direct and still have it right on the tube pin.
