Park Rock Head-ish build
Marshall Amp Discussion
dvnator
Post by dvnator »
I’d thought I’d post my latest build here on the chance there might be some interest in a fairly obscure Marshall amp.
The amp based on/inspired by the Park Rock Head 1210/1240.
For those that don’t know Park amps were built and designed by Marshall but sold under the Park name due to distribution deal/business stuff.
The amp is definitely not a clone as I built it based on parts I had on hand and I did a fair amount of tweaking. Also, the original schematic is a little hard to make out in places.
I used an Antek AS - 2T300 for the PT and the OT is from an even more obscure amp called the Nomad. I didn’t notice any voltages on the original schematic but I’m guessing my amp is at least about 50v lower than the original.
The original Park had a footswitch to change how the guitar signal entered the amp so you could cascade the first two triodes or bypass the “bright” input. I went a different way and did a switch to bypass the second triode and alter the bias on the last triode for the clean “channel”.
My clean channel is very similar to the brilliant channel on the Marshall 2150. The OD sound is somewhere around the JCM800 zone I would say.
It’s built in a blackface chassis I got from Ted Weber years ago and mounted in an old cabinet I got at a thrift store.
It’s not a particularly good looking build, inside or out, but it it sounds pretty good IMHO.
This is the original schematic:
http://schematicheaven.net/newamps/park ... 0_rock.pdf
And this is my schematic:
http://chasingtone.com/dvnator/wp-conte ... hem_v1.jpg
I did some clips. No pedals, just straight in a 2x12 with a Celestion 70th anniversary and a WGS Retro 30.
Playing is not great but you can get an idea of how it sounds.
Clean channel with a Telecaster
Gain channel (medium gain) with a Les Paul
Higher gain setting with a Les Paul
Re: Park Rock Head-ish build
Nice work! Would love to see gut shots.
stephenl
Post by stephenl »
Great sounding amp!
Steve
Vince
Post by Vince »
Hot amp! I like it!
I try to do 2-channel amp after you.
Elements in red circle will be matched to personal preferences.
dvnator
Post by dvnator »
That looks cool Vince. Nice way to split the volume controls.
Just a heads up, when you through the switch there is a bit of a pop when the bias shifts on that last triode. I've looked into ways of avoiding that (mosfet) but it seemed like more trouble than I was willing to do at the moment.
And here is a gut shot. Like most of my amps I built it on a universal turret board. I always do a lot of tweaking and the universal boards help with that. It kind of a tight squeeze and not quite a work of art but it gets the job done.
http://chasingtone.com/dvnator/wp-conte ... 153451.jpg
