Triple checked all connections, re-soldered everything, nothing has changed...
I tried the amp on a variac and the hum makes the B+ jump up and down between 300 and 370(?)VDC (that's with the Variac at 85V). The regular B+ for this amp is around 440V.
Checked the ground, continuity, OT center tap and choke are on the mains 32uf... I can't find where it's coming from...
Tried to get some reading with the tubes in. Brought the variac to approx 115V, turned the standby switch on and blew the mains and HT fuses instantly.
Any ideas?
