Starting with a 2204ish build of mine.
It's got around 480 on the plates of el34's right now.
No experience with bass amps so...
Trolled the web a little & came up with -
Stiffen up the power supply & bring the low end up late in the chain.
I'd really appreciate any input from the gurus here.
Bob
									2204ish to Bass Amp
2204ish to Bass Amp
Why Aye Man
						Re: 2204ish to Bass Amp
I'm not sure it will end up loud enough, but I guess I would look into different output tubes.  Maybe KT88 or 6550.
Thanks for the advice - I suspect the same thing.
I've got some nice 6550's (thanks to someone here) I'll try.
Keeping that fat bottom end tight needs plenty of power on tap methinks.
Why Aye Man
+1 on the 6550's!
Any chance you can go 2203 instead? That 100W seems to bring that bass amp just over the edge into useful power. I know it's only 3dB but it makes a difference to me.
If you only record, you will probably be fine at 50w but for stage - I'd make sure I had a good design on a line out and an effects loop too.
I DO like the sound of a 220X amp as a bass amp - it has a nice feel to it as long as you aren't expecting modern bass amp sounds (tight articulate).
More SVT than Eden.
Cool project though.
More SVT than Eden.
Update.
I re-built this thing 3 times.
Ended up with 6550's & they did it - Thanks Guys!
His old favorite head was a tube Bugera 100W 4x6L6...
Couple of tweeks to get it where it sounded good to him. He couldn't wipe the smile off his face. It moves a lot of air, a Lot. The pt gets warm, but not worryingly warm.
Nice to see someone so focused having fun, he forgot to breathe.
Named it Bruiser after his dog who lost a battle with cancer during this build.
Thanks again guys.
Thanks again guys.
Why Aye Man
