I used an original Drake PT/OT/Choke set from a late 70's JMP 2204 that was supposed to be a little light on the plates...and those reportedly sounded the best!!
JJ Cans, Pihers, a mix of caps...all wrapped up in an Allyn Express chassis.
I decided to pull the bias pot off the board...and i'll probably run some test points to the back panel too.
I got a bunch of nice Takman resistors and ended up using eyelets because I couldn't find my bag of turrets..which I found once i finished the eyelet board.
Ah well, I think it's looking pretty good. I would have liked to clean up the transformer wire runs...but not many options over there. I may throw a Plexi switch in the amp, but I want to see if it's breathing first!!
Hopefully I'll have a good update in a few days....and hopefully I decoded the Drake transfomer wiring correctly!!
Taylor
