18watt plexi
mark enger
18watt plexi
Here's my 18watt plexi, I used a blues jr pt and a newsenser fender ot 8.4k with a 16 ohm only output tap these are pretty sweet ots @ a great price like 20$, and orange drops its a pretty fiery little amp, its very loud and i think the orange drops give it a little different tone than the yellow tubular caps i usually use in my 18watters, Im getting a little hiss out of the treble pot when cranked not real bad, other than that it pretty quiet at idle. mark
Re: 18watt plexi
Nice clean look & wiring. I like the black chassis.
Re: 18watt plexi
Good looking build Mark.
I keep meaning to build an 18 watter.
But the devil keeps sayin "bigger"
Well done. Bet it sounds good too.
Why Aye Man
mark enger
Re: 18watt plexi
Thanks bob, Bigger than a 18 watt marshall, you do need to build one.
Re: 18watt plexi
Mark good looking build.
Recently I built the 18w JCM800 EL84's and also in 2008 or so I build an 18w Plexi EL84's but I think I prefer to use a 6V6 power section, which do you prefer EL84's or 6V6?
mark enger
Re: 18watt plexi
I like the el84, 6v6 in most of my amps seem mushy to me, I have also used el34 and kt66 in this amp, with great results. mark
Re: 18watt plexi
Nice build, Mark!
Can't wait to see what mods you do to the washing machine!
Re: 18watt plexi
I thought Mark's washing machine was part his Rush Tribute band tour.
Re: 18watt plexi
Hahah, very nice! Geddy knows tone is in the washing machineM Fowler wrote:I thought Mark's washing machine was part his Rush Tribute band tour.
Re: 18watt plexi
I'm sure Geddy was using the washing machine spin cycle for his keyboard rotary speaker emulator.Colossal wrote:Hahah, very nice! Geddy knows tone is in the washing machineM Fowler wrote:I thought Mark's washing machine was part his Rush Tribute band tour.
mark enger
Re: 18watt plexi
Washer no it's a amp tester
Re: 18watt plexi
I knew that was part of your work bench...mark enger wrote:Washer no it's a amp tester
Re: 18watt plexi
Oh yeah I've heard of those Whirlpool amp testers, nice.Blackburn wrote:I knew that was part of your work bench...mark enger wrote:Washer no it's a amp tester
Re: 18watt plexi
I find 6v6's to get mushy with high gain amps.Pumping the voltage up to around 450 seems to help.Yes they can handle IT just drop the bias to around 60% OR SOmark enger wrote:I like the el84, 6v6 in most of my amps seem mushy to me, I have also used el34 and kt66 in this amp, with great results. mark
