2204ish JTM kinda
Marshall Amp Discussion
steveneddy
2204ish JTM kinda
Post by steveneddy »
Starting a new build - hoping to have some time this weekend to finish the power section - but here is the pre section so far.
Re: 2204ish JTM kinda
I want to try OD caps in a Marshall some time keep us posted on your build.
steveneddy
M Fowler wrote:I want to try OD caps in a Marshall some time keep us posted on your build.
This is my second Marshall type amp with Orange drops - sounds like a million bucks.
I like the little yellow caps from IC in Bassman and other Fender style amps and if it is going to be a higher gain amp like this one I will install Orange Drops.
I can't put my finger on it but it seems like it defines each note better or something - anyway - I like the result.
In a Fender style amp they are just too clean or sterile or something - but I don't like them in relatively clean amps.
I used those IC caps in some Fender builds too as well as what some suppliers call basic coupling caps (yellow) no markings for brand in 5b6 bassman builds and they sound great. Been using Mojotone Dijon caps as well. Man I'm itching to try another Marshall :) Last high gain 100w AFD#39 build I used film caps.
billyz
Post by billyz »
Depends on the orange drop . 6ps sound good in a fender. 715 too sterile as you say.
