My transformers got here today and I'm excited. I got a pair from RJ, Edcor 600CT and 8K 15W, and a Hammond 1760H(Deluxe 6.6K) to compare. The Hammond looks absolutely puny next to the Edcor. How can it possibly make a bigger sound?
[img
[img
I would agree with this.John_P_WI wrote: Just a suggestion, you may consider changing the V1a plate load to 220k and leave the V1b plate load at 100k.
I agree about the swing being too much (I will elaborate more in the next paragraph) but I disagree with the cathode resistor. When choosing a cathode resistor value, you need to think "What do I want this stage to do?". There are really 3 choices. If you want maximum gain (as in voltage amplification, not distortion) and headroom (like on an input stage), or if you want a symmetrically clipping stage, center bias. If you want to clip the positive half of the waveform seen on the tube's grid, bias it hot. If you want to clip the negative half of the waveform seen of the tube's grid, bias it cold. Biasing two consecutive clipping stages cold is a bad idea because it leads to symmetrical clipping and cancellation of even order harmonics.John_P_WI wrote: I think you will have problems with the 2nd stage as there is over 100 times gain with very little attenuation. It would probably be better to change the cathode to at least a 2k2. You'll easily throw 100 v peak to peak out of that stage with a 1 v input as shown and the 470k - 470k divider will cut this in half.
This is only half true. Ideally, you would actually draw a load line over the tube's curves and figure out how much swing you need on each stage's grid to get the amount of clipping you want. This is typically on the order of 4 to 6 volts if you've biased the stage asymmetrically. To clip the 2nd stage, you need all the gain you can possibly squeeze out of the first stage, but then you need to attenuate it massively in between the 2nd and 3rd stages. Driving the grids positive sounds like ass ONLY if you are getting blocking distortion. A small coupling cap (2n2) plus a big grid resistor (100k) like he's got on the second stage will alleviate this. Grid clamping distortion sounds GREAT when done properly.John_P_WI wrote: Just remember driving the grids positive sounds like ass, build gain slowly across the stages.
Well, I've got the presonance control on the schematic. How do you guys like that vs presence and resonance?John_P_WI wrote:
Finally, IT looks like you are going for the California modded sound, are you going to incorporate feedback resonance?
Oh, you're suggesting using both w/o a switch. I hadn't thought about that. I guess Id need the switch for the diodes thoughReeltarded wrote:The masters work together in an unexpected way. A very good way. Some of the best sounds aren't driving the PI as usual, not nearly.
With the CF dialed back a bit from 100% and the simple master used to set volume range these amps have the most tremendous thump.
My neighbors would love me even more!Reeltarded wrote:You could go commando and switch all masters out.
