Your quite right, the normal channel does make a difference, as does the level control on full, and correct again these all effect the tone. The setup used now is for the best tone.pdf64 wrote: ↑Sat Aug 17, 2019 6:33 pm The manual advises that for max overdrive, the boost channel volume control be turned up full, see p3 https://drtube.com/schematics/marshall/ ... manual.pdf
That makes sense, as it will result in V3a, the stage after the diode clipper, being overdriven.
Additionally, I suggest that all the normal channel controls be turned up full, as their circuits act to load the input stage when they're set low (in the upper registers at least). It may not make much difference, but for the want of a moment's twiddling, it's certainly worth trying![]()
See if those changes are enough, before diving into mods. The downside is that compared to those currently used, the control adjustments might change the boost's overdriven tone a bit.
I think this is the best he is going to get.
Cheers
