xtian wrote: ↑Thu Apr 18, 2019 1:49 am
We're on page 8 of this thread, and I'm too lazy to read it all. Have you tried multiple guitars, to evaluate the ghost note issue?
Yes, three of them, all with humbuckers. Same problem with all. I think the hotter the pickup the worse it got though.
Here is a not so short list of what I tried so far (thanks for all the tips from the guys trying to help in this thread)...
I tried with a 16ohm celestion 50w egnater edition speaker and replaced it with an eminence 75W maverick. I even tried both connected parallel in an 8 ohm setup at 16 ohm and 8 ohm. No luck.
upped the main filter from 32 to 48 uF (changed it back)
upped the PI filter from 16 to 32uf (changed it back)
tried the recommended 'Larry' star grounding
tried the Metro instruction regular buss grounding
tried true one star grounding
Upped the resistors on the V4 and V5 over pin 4 and 6 from 470 ohm to 1k
Added 1k flying resistor (removed when restoring the Metro layout)
Added 5.6k screen resistors to V4 and V5 pin 5 I think
uninstalled the Larmar PPIMV
then reinstalled the Larmar PPIMV
Switched around a total of 7 12AX7 tubes (I have six, one was retplaced due to bad microphonics)
Removed the circuit board resoldered all the leads reflowed all the turrets, inspected them under magnifying glass for cold solder
I ordered a new 3H, 250 mA choke (there is a 20H 70mA in the amp right now), it will arrive tomorrow. I have zero confidence that it will make any difference.
I have a new set of matched and broken in JJ KT66 on the way to replace the Gold Lion's, again I don't believe these will make any difference
I think that's about it so far. None of these things had improved the ghost note issue.
The kit has
Classictone 40-18033 PT 465V B+
Classictone 40-18039 OT
All other components were sourced through Valvestorm
